Interior L.E.D's - Mustang Evolution
Old 10-15-2012, 06:46 PM   #1
03StangGT03's Avatar
Interior L.E.D's
I'm sure this is quite newbish and I accept the laughter at my expense. I installed some LEDs under my dash wired into the cigarette lighter. the LEDs use .24amps reattached the battery and they turned on. When I flipped the switch to turn them off I blew a the fuse which is a 20 amp fuse. I replaced the fuse and the same thing happens. I removed the switch and turned them on and off by touching the positive wires together and it works fine. Does this mean I need a fuse with a higher amp rating? I believe the one I have now is a 10 amp
---------- Post added at 06:45 PM ---------- Previous post was at 06:45 PM ----------
Sorry again!
---------- Post added at 06:46 PM ---------- Previous post was at 06:45 PM ----------
I meant switch not fuse
Travis
03 GT Convertible
03StangGT03 is offline   Reply With Quote
Old 10-15-2012, 06:58 PM   #2
zinc_yellow's Avatar
Region: New Mexico
A higher amp fuse 25 or 30 amp might work but the 10 will definitely blow because it is smaller then the original 20 amp (hope that made sense)
zinc_yellow is offline   Reply With Quote
Old 10-15-2012, 07:00 PM   #3
Zinc I meant switch is a 10 amp fuse is a 20 so do I need a better switch?
Travis
03 GT Convertible
Old 10-15-2012, 07:03 PM   #4
Region: New Mexico
Did the switch and fuse both come with the lights?
Old 10-15-2012, 07:07 PM   #5
No the fuse is the one connected to the cigarette lighter I tied them in together and the switch was just one I bought
Travis
03 GT Convertible
Old 10-15-2012, 07:12 PM   #6
Region: New Mexico
I would say the switch.. I've wanted to put some LEDs in my car just for a little more light when you open the doors.. nothing ricey haha
Old 10-15-2012, 07:14 PM   #7
Mine are under the dash and I just wanted to toggle it with a switch they work fine without the switch but no way to turn them off. I am pretty sure it is the switch because its only rated for 10 amps and its a 20 amp fuse
Travis
03 GT Convertible
Old 10-15-2012, 07:17 PM   #8
Region: New Mexico
I was ganna say just wire them in with your dome lights.... Then I realized you have a vert haha.
Old 10-15-2012, 07:36 PM   #9
I have lights on my rear view but I'd rather have them be on while doors are shut to
Travis
03 GT Convertible
Old 10-15-2012, 07:39 PM   #10
Region: New Mexico
Makes sense. Let me know how they turn out.
Old 10-15-2012, 07:46 PM   #11
I'll post pics hopefully tomorrow
Travis
03 GT Convertible
Old 10-15-2012, 07:47 PM   #12
Region: New Mexico
Sounds good. Where did you get the lights from and how much?
Old 10-15-2012, 07:49 PM   #13
Autozone and they were like 30 bucks for 2 12 inch lights
Travis
03 GT Convertible
Old 10-15-2012, 07:52 PM   #14
jdavis96gt's Avatar
Region: West Virgina
Wire it off the radio
Old 10-15-2012, 07:53 PM   #15
Region: New Mexico
I've looked at those too!
Old 10-15-2012, 08:02 PM   #16
I could do that but I'm going to try a better switch first I think
Travis
03 GT Convertible
Old 10-16-2012, 11:45 AM   #17
Well I feel dumb. The problem was I had the negative also on the switch. I should have just grounded it directly to the cigarette lighter. They work fine now
Travis
03 GT Convertible
Old 10-16-2012, 02:47 PM   #18
1shotkllz's Avatar
Pics??
1shotkllz is offline   Reply With Quote
Old 10-16-2012, 05:45 PM   #19
jdavis96gt's Avatar
We all have them kinda days lol. Congrats on figuring it out. Pics
Old 10-16-2012, 07:22 PM   #20
They are actually a brighter green then these pics show. Also ignore the crappy switch placement! I plan on cutting a hole and inserting it next to the convertible top switch
ID:	72528   Click image for larger version
Travis
03 GT Convertible
Old 10-16-2012, 07:26 PM   #21
Another pic
Travis
03 GT Convertible
Old 10-16-2012, 07:39 PM   #22
Region: New Mexico
Looks nice. Those are really bright
Old 10-16-2012, 07:59 PM   #23
Thanks Zinc if you want some I say go for it!
Travis
03 GT Convertible
Old 10-16-2012, 08:36 PM   #24
Region: New Mexico
Maybe clear or blue. Idk for my yellow stang haha
Old 10-16-2012, 08:37 PM   #25
Another pic
That looks good! Mine are purplish, been thinking of redoing them red.
Get some yellow or gold lights!
Old 10-16-2012, 09:49 PM   #26
Region: New Mexico
Good idea
Old 10-17-2012, 12:16 PM   #27
I think yellow would be amazing
Travis
03 GT Convertible
Old 10-17-2012, 04:58 PM   #28
LAS97GT's Avatar
I've been planning the same. Sharing my idea: autozone has a 12" strip that has the lights that run center to end, reddish amber colored. Problem is how to have it turn on only when the door opens etc. any ideas?
---Las97GT
Old 10-17-2012, 05:27 PM   #29
Region: New Mexico
Theres a switch by the door that turns on the dome lights I plan on just splicing into that
Old 10-17-2012, 06:58 PM   #30
That's exactly where I tapped mine into
Old 10-17-2012, 08:14 PM   #31
Region: New Mexico
Did you just use that door swith to turn them on and off and as a power source or did you wire a separate wire for power?
Old 10-17-2012, 09:36 PM   #32
I ran them to the interior lights. If the doors are open or my map light are on, my LEDs are on
Old 10-17-2012, 09:43 PM   #33
93slowstang's Avatar
Moved to appearance and detailing.
Old 10-18-2012, 08:31 PM   #34
MachMan1017's Avatar
Would you be able to further explain in detail what you had to do to make this work? Because Since I got the mustang I wanted to do this.. But only if I could get a switch to turn them on an off whenever wanted.( what did you remove? Tools used?)
Would really appreciate it!
MachMan1017 is offline   Reply With Quote
Old 10-18-2012, 08:40 PM   #35
Region: New Mexico
Where did you tap into the dome light? Roof, fuse box?
01:39 AM
