Worried to plastidip? - Mustang Evolution
Old 11-27-2012, 03:55 PM   #1
MachMan1017's Avatar
I really want to do my rear valence to tie it all together.
I have done a few test sprays, it comes out blotchy? Im just worried about spraying it on my car and it not coming off?
Anyone else worried like this before using on your car? If so did you have a good first try on your car?
MachMan1017 is offline   Reply With Quote
Old 11-27-2012, 04:02 PM   #2
Venomouz831's Avatar
Lol it does come off. No need to worry about harming you're car
)02 Gt, Founder of WE2G
Old 11-27-2012, 04:20 PM   #3
1slosix's Avatar
If you spray light even coats it wont blotch once it dries...4-5 coats for your valence. I did mine without ever using the stuff before and no spray tests and it came out great. Plus it does come off nicely.
carving corners like a boss
Old 11-27-2012, 04:24 PM   #4
What should I use to tape off? Just tape and newspaper?
And when should I remove the tape when done? About a minute after applied?
How long should I wait between coats? And if I do about 4-5 coats, just pull the tape off after the last spray?
Thanks for the help in advance, MachMan1017
Old 11-27-2012, 08:01 PM   #5
Black on Boss's Avatar
Just tape and newspaper.
Remove tape carefully so you don't pull everything off.
Wait a few min between coats.
Old 11-27-2012, 11:03 PM   #6
BaSohol's Avatar
I masked it off like this and plastidiped my whole hood almost
ID:	78144   Click image for larger version
2007 Ford Mustang GT 5spd
Old 11-27-2012, 11:24 PM   #7
Zweissk8's Avatar
I plasti dipped my rims and it came our great! Also it peels easily but very durable... If that makes sense.
Zweissk8 is offline   Reply With Quote
Old 11-27-2012, 11:31 PM   #8
m_tyler_r's Avatar
take a couple of hours and watch a lot of YouTube videos if you aren't okay with it... it'll make you a pro
Betty White
2012 V6
m_tyler_r is offline   Reply With Quote
Old 11-28-2012, 12:27 AM   #9
1slosix's Avatar
i used trash bags to mask off the car....i just tore them open and i covered the back half of the car in i think 4 bags...then taped the lines for the panel...pull the emblem off with some fishing line...cleaned off the area...then sprayed it down with light coats till i was satisfied...then when i went to pull the tape even slowly i noticed it trying to tear the edge..so i took a razor and lightly scored the edge of the dip where it met the tape...then slowly pulled the tape. left a perfectly clean line...it was so easy and the whole process took less then 30 minutes.
Old 11-28-2012, 01:23 AM   #10
WheelStander's Avatar
You didn't have locator holes in your deck lid where the gt and ford emblem were?
Nice cars too fellas.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 11-28-2012, 05:22 AM   #11
+1
---------- Post added at 07:22 AM ---------- Previous post was at 07:20 AM ----------
A little trick is to spray the edges with another lite coat right before you peel them off. YouTube will make you a pro lol
Old 11-28-2012, 12:41 PM   #12
StangerBanger04's Avatar
When you have your wheel off and apply plasti dip to it and after it dries enough to put your wheels/tires back on your car does it come off since you're using your hands to put them back on? I'm confused about that. Cause I'd hate to spend all the time and soon as I put my wheels back on it peels off..
StangerBanger04 is offline   Reply With Quote
Old 11-28-2012, 12:54 PM   #13
BaSohol's Avatar
No not at all, I scrub my hood and rims and yet to have it peel yet
Old 11-28-2012, 01:13 PM   #14
How do you clean plasti dip stuff like wheels and hoods?
Old 11-28-2012, 01:30 PM   #15
Zweissk8's Avatar
I just pressure wash it. Dirt comes right off.
Old 11-28-2012, 01:33 PM   #16
Missxalii's Avatar
Send a message via AIM to Missxalii
It looks like that when it sprays. But when it dries it's flat. And with a coat or two it will easily peel off.
2012 Dub Edition V6 Mustang
full borla exhaust / steeda intake / 3.73's / aluminum driveshaft
exedy stage 3 clutch / spec steel flywheel / steeda shifter bushings
Missxalii is offline   Reply With Quote
Old 11-28-2012, 01:44 PM   #17
Mustang32Bill's Avatar
Mustang32Bill is offline   Reply With Quote
Old 11-28-2012, 01:45 PM   #18
I did my scooter lol then painted orange tiger stripes over the dip aha
Old 11-28-2012, 01:50 PM   #19
DerekJohnScott's Avatar
Does the surface have to be a smooth glossy suface?
DerekJohnScott is offline   Reply With Quote
Old 11-28-2012, 01:52 PM   #20
BaSohol's Avatar
It would aid in removal I'm sure
Old 11-28-2012, 01:58 PM   #21
It goes on pretty thick so it doesn't really matter I think
Old 11-28-2012, 03:16 PM   #22
JetLife 01GT's Avatar
Go to dipyourcar.com. They have guides and how to YouTube videos. Answers all the questions every has asked
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-28-2012, 04:57 PM   #23
Zweissk8's Avatar
Just remember to wipe down the surface with rubbing alcohol using a paper towel. This way you get rid of all dirt.
Old 11-30-2012, 08:58 AM   #24
BaSohol's Avatar
I removed my DiP this morning took 3 mins for all four! Just spray it on thick
Old 11-30-2012, 10:21 PM   #25
1slosix's Avatar
there aren't any holes behind GT emblems (i learned that from my old '04)...but there are two behind the Ford emblem...in that pick i had them plugged with nylon plugs i got from a hardware store because at the time i wanted the debadged look...now i got the emblem back on
Old 12-01-2012, 12:41 AM   #26
This hasn't been said yet, and i HOPE it is obvious but i am going to say it anyway... When masking with tape, use something like blue painters tape, or something with not a lot of tack... NO Duct Tape lol
Old 12-04-2012, 10:08 AM   #27
The 99 gt deck lid had holes and squares under the gt and ford logo yeah.
Think 99 and 00 are like this.
02:59 PM
