Side Scoop Removal - Mustang Evolution
Old 02-06-2013, 07:31 AM   #1
V6in's Avatar
Side Scoop Removal
I havent found a way to remove the side scoops for my car. Has anyone tried this? I want to put the covered ones in.
ID:	89463   Click image for larger version
V6in is offline   Reply With Quote
Old 02-06-2013, 07:33 AM   #2
1slosix's Avatar
Flat head screwdriver wrapped in a rag does the trick. If you break some of the push pins holding it down you can always buy new ones at any autoparts stores
carving corners like a boss
Old 02-06-2013, 07:34 AM   #3
V6in's Avatar
Is it just as easy to put new ones in? I'm most likely getting some off a GT
Old 02-06-2013, 07:35 AM   #4
Or just grab and pull. Right before you think it will break it will pop off.
Six plastic pins on each scoop. Several will probably stay on the car.
Old 02-06-2013, 01:10 PM   #5
SCCofSV's Avatar
Or if you have some monofilament line (fishing line) some Dawn dish washing soap mixed with water (lubricant) you can spray that around the scoop and then slide the line underneath the 3M tape! It will cut through the tape without damaging the cars paint or do it dry but not sure of the friction. The point it is there will be no chance of scratching your car if you accidently slip. It does work and quite well. Perhaps not as fast as the other ways.
---------- Post added at 12:10 PM ---------- Previous post was at 12:07 PM ----------
Oh yeah! I forgot to mention this. Side the line back and forth in a sawing matter or as if sawing something.
SCCofSV is offline   Reply With Quote
Old 02-06-2013, 01:13 PM   #6
Rich04's Avatar
Took mine off the other day. U pretty much just pull and slide them
Rich04 is offline   Reply With Quote
Old 02-06-2013, 01:23 PM   #7
Moostaang11's Avatar
Take off the honey comb inserts out first then ull have better grip pullin it out that way with ur hand inside
Moostaang11 is offline   Reply With Quote
Old 02-06-2013, 01:28 PM   #8
1slosix's Avatar
Maybe on an s197 but new edges are held on with push tabs
Old 02-06-2013, 02:03 PM   #9
Compstall's Avatar
I just saw a white Mustang like yours yesterday. Looked like the owner smeared a concrete wall on the passenger side. Either way, that could be an option, as his side scoop looked like it came off fairly easily that way. :p
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 02-06-2013, 02:18 PM   #10
V6in's Avatar
Haha I don't think I'm gonna try that LOL
Old 02-06-2013, 03:31 PM   #11
SCCofSV's Avatar
Thank you, I wasn't aware of that and it's a good thing to know!
06:46 AM
