Day 20 of make over - Mustang Evolution
Old 03-23-2013, 04:32 PM   #1
Allans03ragtop's Avatar
Day 20 of make over
Did more hand rubbing on corners, ridges and crevices.
Then my brother came down stairs and pulled out the buffer just to give me a tease, and buffed one side scoop and about half the hood.
ID:	97888   Click image for larger version
ID:	97891   Click image for larger version
03 Sonic Blue CONVERTIBLE W/STYLE BAR AND SPEEDSTER COVER AND 18X10W/275/35 REAR AND 18X9W/245/45 FRONT. OFF ROAD X-PIPE 40 SIERIES FLOMASTERS AND CAI.
Allans03ragtop is offline   Reply With Quote
Old 03-23-2013, 05:25 PM   #2
Ghostedmind's Avatar
I may have just missed it in previous posts but, what are you using for the buffing?
LCMC Member
Old 03-23-2013, 06:10 PM   #3
If you are asking what compound we are using it is a 3M product called perfect it. We will buff it with compound no.1 and then we will go back and polish it with compound no.2
I am just using a soft cloth with my hand and we will use a painters buffer and buffing pad, then change to the polishing pad to polish it. We have not polished anything yet only started buffing.
Old 03-24-2013, 05:16 PM   #4
Day 21 of make over
Got the inner fenders under coated, and the trim that goes around the side and back of top primed. Also sanded the clear coat on the speedster covers. Drilled holes in side panels for the style bar to go through, and the ones to put the bolts through to bolt it on.
ID:	98160   Click image for larger version
ID:	98162   Click image for larger version
Old 03-24-2013, 06:11 PM   #5
One other thing on the buffer my brother is using. It is a Mikita and it is variable speed and that is a must for buffing paint. He also uses a wool pad to buff it with the No1 compound and a foam pad to polish it with the No2 polish.
01:46 PM
