Fix or replace? - Mustang Evolution
Old 04-12-2013, 06:56 AM   #1
TiffStar's Avatar
Fix or replace?
Just bought a 96 V6, runs great but needs some lovin. Just looking for some advice on whether to fix certain areas or just replace the parts. Also, what would be the least expensive way to get it done without making her look trashy? A few pictures are attached, more in my profile album.
Name:	New Stuff 005.jpg
ID:	102071   Click image for larger version
Name:	New Stuff 010.jpg
Name:	New Stuff 009.jpg
ID:	102073   Click image for larger version
Name:	New Stuff 011.jpg
TiffStar is offline   Reply With Quote
Old 04-12-2013, 08:24 AM   #2
maldog's Avatar
Region: Nevada
I'd fix it. Try not throwing to much $$$$ into it.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 04-12-2013, 08:38 AM   #3
TiffStar's Avatar
Like sanding and re-painting? What about the tire wells, does that need cut out/welded? and the hood/fender(driver side), how do I go about fixing that?
Old 04-12-2013, 09:06 AM   #4
rebeltx's Avatar
Not sure how much luck you will have saving the paint. You can improve on it but it won't look new without new paint.
The rusted finder will need to be cut out or replaced. Rust is like cancer, if you don't cut it all out it will just grow. Your trunk may be surface rust. If you can sand it all out you would be ok as long as you seal it. The hood looks like sun damage, you should sand down the edges, maybe even wet sand it. Problem is you don't have much clear coat left on the hood now. The whole car could use a good wax and polish, that would take you a long way and let you see the true extent of the damage. Wash it with dish soap first then polish it with a good compound after you sand problem areas.
Good luck
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 04-12-2013, 09:33 AM   #5
TiffStar's Avatar
Thank you Rebel, now I have an idea of where to begin. Let the fun begin!
06:32 AM
