Cobra front bumper need help - Mustang Evolution
Old 05-16-2013, 02:24 AM   #1
Blackedout03's Avatar
Region: Delaware
Hey everyone been a while since I posted (broken phone) but I was looking hard into getting the 03/04 termi front bumper but I have seen mixed reviews some saying I need the termi hood and most people saying you don't so if anyone has any input it would help out a lot. Thanks
Blackedout03 is offline   Reply With Quote
Old 05-16-2013, 05:16 AM   #2
Horseplay's Avatar
u dont really need it, but ur probably gona have trouble closing ur stock hood properly. but several people buy termi bumpers and keep stock hoods so it shouldnt be a big deal
Low2v
Old 05-16-2013, 08:33 AM   #3
Region: Delaware
Would it work if I cranked my hood adjusters just enough or would that not work
Old 05-16-2013, 09:20 AM   #4
the 03/04 cobra hood is a bit different in the area that goes up by the headlights (the points) it is a bit higher than the OEM v6/gt bumper (about an inch or so taller).
You can look at the V6/GT version and see its flat at the top where the push pin goes but on the 03/04 its not flat it has an indentation.
The OEM hood will rub a bit here and ive seen it happen. Some modify it to work~ or you can get an 03/04 cobra hood
as you said you may can adjust the hood adjusters but then the hood will not line up with the fenders
Old 05-16-2013, 09:22 AM   #5
ToHellAndBack's Avatar
I have a termi bumper with a stock hood. All you have to do is change where the top of the bumper mounts. Drill holes about a half inch back on the headlight pannel and it moves the top of the bumper back so your hood doesn't rub. I'll try to find some pics to explain this
"I'm not tailgating... I'm drafting"
ToHellAndBack is offline   Reply With Quote
Old 05-16-2013, 09:39 AM   #6
Here you go. The third pic shows where my first cobra bumper rubbed my hood. In the last pic, the further back hole allows the bumper to be just that much lower so it won't rub, hope this helps
ID:	108474   Click image for larger version
ID:	108476   Click image for larger version
Old 05-16-2013, 12:40 PM   #7
Region: Delaware
Thanks man that's helps a lot
04:54 AM
