Hood Scoop Falling Off - Mustang Evolution
Old 06-14-2013, 11:47 AM   #1
GHO5T5NIPER's Avatar
Hey guys my hood scoop is starting to peel off in the front of it.. It's the stock scoop so I don't think it can be drilled on right? I think that they are just taped or glued on. What do you guys recommend to secure it back on? I think the glue probably was loose from the heat and driving down the highway I could see it was about to fly of so I had to stop. I guess I was going to too fast and had "Danger to Manifold" all you fast an furious fans out there will get that haha.
GHO5T5NIPER is offline   Reply With Quote
Old 06-14-2013, 11:52 AM   #2
Allans03ragtop's Avatar
Originally Posted by gho5t5niper View Post
hey guys my hood scoop is starting to peel off in the front of it.. It's the stock scoop so i don't think it can be drilled on right? I think that they are just taped or glued on. What do you guys recommend to secure it back on? I think the glue probably was loose from the heat and driving down the highway i could see it was about to fly of so i had to stop. I guess i was going to too fast and had "danger to manifold" all you fast an furious fans out there will get that haha.
Attachment 114026
it should have seven bolts with nuts that hold it on. My 2003 gt does. I just painted it and took it off. You have to remove the heat shield from under neath the hood to get to them.
03 Sonic Blue CONVERTIBLE W/STYLE BAR AND SPEEDSTER COVER AND 18X10W/275/35 REAR AND 18X9W/245/45 FRONT. OFF ROAD X-PIPE 40 SIERIES FLOMASTERS AND CAI.
Allans03ragtop is offline   Reply With Quote
Old 06-14-2013, 12:29 PM   #3
So would I just need to secure the part that has come off with some adesive tape? Am's hood scoop they sell is taped on with 3m tape and adhesive pad. So should I go buy some and do that on the part that came loose?
Old 06-14-2013, 12:30 PM   #4
slow281
sixpac's Avatar
Region: Nebraska
If its oem it should be drilled on..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-14-2013, 12:36 PM   #5
Venomouz831's Avatar
Oem is drilled and aftermarket usually tape
)02 Gt, Founder of WE2G
Old 06-14-2013, 12:37 PM   #6
So should I remove the whole thing and redo it? Just the front has came loose the rest is still on
Old 06-14-2013, 12:39 PM   #7
Pop you're hood up, Take off the heat shield, tighten bolt.
Old 06-14-2013, 12:39 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
Yeah.. New 3m tape and new nuts ect.
2001 GT - True Blue
Old 06-17-2013, 04:04 PM   #9
Vintage Iron's Avatar
That was good. You cannot get any clearer than that
Vintage Iron is offline   Reply With Quote
Old 06-18-2013, 10:54 PM   #10
I took the heat shield off, took the whole scoop off and found out one of the "screw clamps" was broken. I jd welded it and put it back in place and put the scoop back on and has been fine ever since. I thought these things were glued or taped on. AM sells a glued version so i guess ivwas just assuming haha. Thanks guys!
Old 07-23-2013, 02:28 PM   #11
Well the fix was short lived... About flew off again today. About to break down and by a cowl hood
Old 07-24-2013, 05:25 AM   #12
Project Pony's Avatar
I recently bought the one from AM. It uses several bolts and 3m tape.
[SIGPIC][/SIGPIC]
Old 07-27-2013, 10:26 AM   #13
Do you use the 4m tape to attach the scoop directly to the hood? Or does it hold the "weatherstripping looking stuff together if that makes sence. Might not lol but that's what my problem is the weatherstripping material keeps coming loose causing the scoop to come loose
Old 07-27-2013, 12:04 PM   #14
It didn't have any weather stripping. Just 3m tape stuck to the bottom of the scoop and seven bolt brackets.
[SIGPIC][/SIGPIC]
10:19 AM
