Leather seat options - Mustang Evolution
Old 07-09-2013, 01:20 PM   #1
bigmac3's Avatar
Has anyone ever replaced seat covers with leather pull-offs. If so, what kind of problems do they present?
Has anyone ever mounted power seats in a non-Premium model? Are the power wires already there and simply not used or do you have to run your own power?
I'm just trying to weigh a few options here. I have also found a set of new covers from LeatherSeats.com in OKC for $749.00 and could have them installed locally. Anyone familiar with them?
I just got a quote of $2,500.00 for new leather seat covers from a local trim shop. They order them from California. I could do that myself and possibly save some bucks. All in all, seems a bit much compared to what I have paid before. Thanks in advance.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 07-09-2013, 02:02 PM   #2
eBay for leather seat covers is a better idea. Either that or buy racing seats that are leather, as they would be probably of nicer quality leather and less expensive than ford seats.
Also, base cars don't have the connectors for the power seats but you can splice into the power from other areas
Old 07-09-2013, 02:15 PM   #3
bigmac3's Avatar
Thanks ZLwhat. E-Bay is where I found the pull-off seat covers I mentioned. They have them Buy-It-Now for $495 to $999, depending on what they came out of. There are a few I liked. Just not sure if that is the way to go.
Frank
Old 07-09-2013, 03:21 PM   #4
Well my gt premium is a 2012 and my seats are leather and they have already began gettin little creases and things from every day use. There are no other signs of wear so I would like to think they would last a long time. However, I have corbeau custom racing seats in my lightning and they are suede with leather inserts. They are far more comfortable than my 5.0s seats and they are built way better. I spent $699 per seat with every option including 5 point harnesses and another $200 for the brackets.
Old 07-11-2013, 09:39 AM   #5
Hit up the roush ebay store and buy leather takeoffs from a 2012-2014 model for $350. Its a no brainer. I installed mine myself and it wasn't that bad, just time consuming. If you have the tilt headrests in front you will need to source some new leather covers for those because the ones that come in the roush kit dont fit. I found some locally for cheap as well. Very first thing I did to my car.
Finkikus is offline   Reply With Quote
Old 07-11-2013, 01:04 PM   #6
bigmac3's Avatar
Thanks, they look great. That's what I had in mind, just don't know what I'm doing. How did it affect the air bags?
Frank
Old 07-11-2013, 03:43 PM   #7
the airbag thing is on the leather seats so i'm guessing they are unaffected. i left them in and i can only assume the GT premium that these came out of had side airbags in the seat as well
Old 07-11-2013, 04:07 PM   #8
bigmac3's Avatar
I've got an '11 V6 base model with seat airbags. I'm not sure what has to be disconnected and then reconnected. I found a set of take-offs on e-bay that are reasonable. They are for a '12 so the headrests are different but I can live with cloth headrests.
Frank
Old 07-11-2013, 05:07 PM   #9
There's a 2 connections under each seat. I'm 99% sure the airbag is in the same place so I wouldn't worry about it. All you do is disconnect the negative terminal on the battery and wait a min or two, then unbolt the seats and disconnect the wires. There's a very helpful video I followed here. The only hurdle I encountered was I broke a plastic tab when taking off the panel on the passenger seat. I had to buy a new one from the dealer. Be careful when popping those off.
Which headrests do you have?
Old 07-11-2013, 10:12 PM   #10
bigmac3's Avatar
I have the ones like in the video bit the covers I'm looking at are for a '12-'14 which are shorter and rounder.
Frank
Old 07-12-2013, 09:31 AM   #11
Yeah after looking at the video I can see the ones are different than on the Roush eBay store. I knew mine were different when I got them so I had to source the covers I needed which I also found on eBay for rather cheap. Then I found them on craigslist for even cheaper but it was already too late at that point. You'll be able to find them eventually i'm sure, it just takes a little patience. If you really want to splurge you could order the adjustable headrests with leather from AM. I have the tilting ones that came from the factory and love them.
Tilting Mustang Headrest Black Vinyl - Pair (10-14 All) 43-78810 - Free Shipping!
You could also order different foam for your current headrests from your dealer to match the leather covers you receive.
Old 07-12-2013, 09:47 AM   #12
bigmac3's Avatar
You'll be able to find them eventually i'm sure...
I bid on a set out of a GT500 this morning that are black with red stripes. Those will match my car real nice. They have my style of headrest. Got my fingers crossed.
Frank
Old 07-12-2013, 12:08 PM   #13
I wish you the best of luck on those!
Old 07-12-2013, 12:59 PM   #14
bigmac3's Avatar
Thanks, I'll need it. Looks like work ahead of me.
Frank
Old 07-12-2013, 02:07 PM   #15
It's really not that bad, it just takes time. Your fingers will be a little sore afterwards but its totally worth it. I can't think of any other car where you can source leather seats this cheap and have them installed within a day doing it yourself.
Also, don't even bother re-using or buying new hog rings, just use zip ties and snip them off. So much easier and the same effect.
Old 07-12-2013, 02:15 PM   #16
bigmac3's Avatar
Gump, you're a genius. LOL. That's a great idea.
Frank
Old 07-12-2013, 02:31 PM   #17
Aruiz42's Avatar
I did it myself... Look up my old threads... Installed myself from roush... There are YouTube videos showing how to do it... Ill help as much as possible if you want
---------- Post added at 04:31 PM ---------- Previous post was at 04:31 PM ----------
Also used zip ties
Aruiz42 is offline   Reply With Quote
Old 07-12-2013, 11:39 PM   #18
Best movie ever, well maybe in a tie with Saving Private Ryan
Old 07-12-2013, 11:46 PM   #19
bigmac3's Avatar
Best movie ever
Have to agree.
Frank
Old 07-13-2013, 09:13 AM   #20
so did you win those seats? i couldn't find the auction so i'm assuming its over
Old 07-13-2013, 11:38 AM   #21
bigmac3's Avatar
Apparently I did. Got them for $600.00, shipping included. Here they are.
Frank
Old 07-13-2013, 11:50 AM   #22
Thats freaking awesome! Now you're going to have nicer seats in your V6 than your GT
Old 07-13-2013, 12:45 PM   #23
bigmac3's Avatar
Actually I think the V6 is a prettier car than the GT (I still like the '11 grill better than the '13). Of course the power is sunstantially better with the GT but the V6 gets more attention and compliments. When I give rides to non-Mustang types, they are so impressed and cannot believe its a V6.
Frank
Old 07-19-2013, 10:37 AM   #24
can buy these online. more difficult to upkeep though..
ErikMustang is offline   Reply With Quote
Old 07-20-2013, 09:44 PM   #25
bigmac3's Avatar
The red/black covers arrived yesterday. They are beautiful and should really look good in the car. Unfortunately I still have to wait two more weeks before the trim shop can get to them. Oh well, what's a few more days? I've owned the car three years next week.
Frank
Old 07-20-2013, 10:52 PM   #26
It's really a simple job to do yourself Frank. Took me a day and a few beers and a lot of breaks. I guess if your a busy guy then let someone else do it though.
Old 07-21-2013, 06:08 AM   #27
bigmac3's Avatar
Not busy...old and lazy. I've gotten to the point where the doing is not as much fun as the enjoying, though the beer part sounds good. LOL.
Frank
Old 07-21-2013, 08:40 AM   #28
Aruiz42's Avatar
It's real simple... I did it with a few beers also lol... Is your old leather torn and worn?
Old 07-21-2013, 08:55 PM   #29
bigmac3's Avatar
My car is a base model with cloth seats. I'm moving up to leather.
Frank
Old 07-22-2013, 07:09 AM   #30
Aruiz42's Avatar
Ooh.. Ok... Well have fun haha... I did the same.,. Looks good!!
Old 07-23-2013, 10:50 PM   #31
took me a day to do my seats. Alot of pulling to get them right happy how mne turned. ordered on ebay from roush.
mustangmaniac06 is offline   Reply With Quote
Old 08-05-2013, 09:34 PM   #32
bigmac3's Avatar
Well the day finally come and Li'l Red got her snakeskins.
ID:	122226   Click image for larger version
ID:	122228   Click image for larger version
Frank
Old 08-06-2013, 12:06 AM   #33
cheelyb09's Avatar
Looks great.
how much did it cost to get them installed.
I plan on doing mine soon.
Old 08-06-2013, 12:09 AM   #34
Venomouz831's Avatar
Those look great!
)02 Gt, Founder of WE2G
Old 08-06-2013, 05:45 AM   #35
bigmac3's Avatar
$450.00, worth every cent. Went to a local trim shop and got it back in four hours.
Frank
04:53 AM
