I need help... - Mustang Evolution
Old 08-06-2013, 09:34 PM   #1
clflorida's Avatar
Region: Arkansas
I need help...
Tyring to install these http://www.americanmuscle.com/99-04-...low-gauge.html white reverse guages. They were working for awhile but after a few seconds of messing with the switch, they turned off. This is what it looks like with lights on.(pic 1) As you can see thats all I can see. The dimmer does nothing now. I think it was turned on the whole time at work. From what I know, the red wire that I had to solder is good. But the black wire that I need to ground is being held by electrical tape. I think thats the problem. But idk how to make it stay without the tape. Ill try removing the gauge cluster and ill update you then.
clflorida is offline   Reply With Quote
Old 08-06-2013, 11:02 PM   #2
clflorida's Avatar
Region: Arkansas
Well. Apparently I'm the only person who has these. I thought the black wire was loose I guess it was I added much more electrical tape this time...its not going anywhere. So that problem solved. Now how do I turn them off? Like I said the whole time at work they were on. Does anyone know how I turn them off? If they stay on they'll drain the battery yes? Unacceptable. I was pretty sure I soldered the red wire to the headlight knob, but idk. I have a picture of the control box thing...I know you can't see it too well but I soldered the red wire to the brown wire behind the blue wire next to the big gray wire. This was supposed to be a simple 1 hour installation and its becoming one of the hardest things I've ever done...
12:03 PM
