Need help, will these wheels fit? 2013 v6 - Mustang Evolution
Old 09-19-2013, 09:15 AM   #1
Ok I may be buying some rims with the following dimensions.
Number of Bolts: 5
Rim Material: Alloy
Bolt Pattern: 5x114.3
Rim Width: 20x8.5 & 20x10
Hub Bore: 70.6
Rim Diameter: 18
Rim Structure: One Piece
Offset: +30mm & +43mm
Will these fit a 2013 mustang V6 or did I just shoot myself in the foot.
Also if they do fit, what sort of tire am I going to want to put on em?
Ponyboarder is offline   Reply With Quote
Old 09-19-2013, 03:09 PM   #2
bigmac3's Avatar
Number of Bolts: 5
Rim Material: Alloy
Hub Bore: 70.6
Rim Diameter: 18
So are they 20"s or 18"s? It's easiest if you know what they came off of. My guess is that they will fit. The most common tire combos are 245/45 or /40 fronts and 285/40 or /35 rears.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 09-19-2013, 04:21 PM   #3
they are 20's, and from what I hear if you dont put the right tire size it will put your speedometer off
Old 09-21-2013, 09:59 AM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
That's true because different tires may have different revolutions per mile, which will throw the speedometer off. It's all based off of your rear wheels too. Find out what the revs per mile are for your stock wheels and see if there's a tire with similar revs per mile that will fit the rear wheels you're looking at buying. Your speedometer may still be slightly off, but it should be easily manageable.
2012 Kona Blue 3.7L V6:
09:21 AM
