Clear coat problems - Mustang Evolution
Old 10-11-2013, 12:39 PM   #1
98GTCONV's Avatar
Clear coat problems
I was putting on a new decal and tore the backing off. Well now my clear coat is bubbling and came off with the backing. How can I fix this?
98GTCONV is offline   Reply With Quote
Old 10-11-2013, 12:41 PM   #2
mystang50's Avatar
oh **** man!!that sux!!
Old 10-11-2013, 12:43 PM   #3
98GTCONV's Avatar
As I was peeling, I'm thinking, **** me lol.
Old 10-11-2013, 12:49 PM   #4
PonyBoyV6's Avatar
I can say honestly, i have never seen that happen before
PonyBoyV6 is offline   Reply With Quote
Old 10-11-2013, 12:52 PM   #5
98GTCONV's Avatar
I haven't either. That's why I wasn't worried about it. Now it looks like ****.
Old 10-11-2013, 12:53 PM   #6
98GTCONV's Avatar
Other side looks great lol
Old 10-11-2013, 02:13 PM   #7
98mustang_gt's Avatar
You're going to have to sand, buff and do a fresh layer of clear coat. I'd do it ASAP because the same thing happened to me and it just kept getting worse and worse.
98mustang_gt is offline   Reply With Quote
Old 10-11-2013, 02:21 PM   #8
98GTCONV's Avatar
How much would a paint shop charge to do that?
Old 10-11-2013, 04:22 PM   #9
2 Stangz's Avatar
Region: Nevada
There's no way... Are you sure that's not just leftover adhesive/residue from the sticker? I spent ab 8-10 hours removing my 12in lemans stripes from my pony and it left tons of residue which took most of the time to remove.
Old 10-11-2013, 04:37 PM   #10
jduckz5.0's Avatar
Wow that sux....looks like its peeling up over the edge as well???with the cost of paint and materials these days you might be looking at $500...
jduckz5.0 is offline   Reply With Quote
Old 10-11-2013, 04:41 PM   #11
Prices are going to vary. It really depends who you go to. But $500 sounds about right.
Old 10-11-2013, 05:09 PM   #12
jduckz5.0's Avatar
And you will have to buy new decals...
Old 10-11-2013, 05:34 PM   #13
+1
Old 10-12-2013, 12:30 AM   #14
98GTCONV's Avatar
It's not left over. I can touch is and it bubbles up and creates a bigger spot.
---------- Post added at 01:30 AM ---------- Previous post was at 01:28 AM ----------
Good lord $500? Might as well strip the whole hood down. That small spot can't just be clear coated? Because the other side didn't do that.
Old 10-12-2013, 01:18 AM   #15
You can spot paint it if you like. It'll be cheaper. But you'll eventually notice the difference in the clear coats.
Old 10-12-2013, 07:01 AM   #16
jduckz5.0's Avatar
Yes the whole hood needs decals removed,,,wet sanded,,,,clear coat,,,,wet sanded again,,,,then decals placed back on...I would remove and hang hood to spray it..much less work and cleaner finish....
Old 10-12-2013, 01:09 PM   #17
2 Stangz's Avatar
Region: Nevada
Ah man, that is a damn shame. Yeah, typically when you paint a panel you have to paint the whole panel at once (like I said typically, I'm not a pro painter). Quality hood paint jobs are usually in the $500-$600 range.
Old 10-12-2013, 01:12 PM   #18
Slow4V's Avatar
I got quoted for 150-200 to paint my hood
Same guy that did my front bumper .. Good work
Old 10-12-2013, 03:13 PM   #19
jduckz5.0's Avatar
Damn that's cheap....I do my own work and just for materials it costs me $100...
---------- Post added at 04:13 PM ---------- Previous post was at 04:12 PM ----------
Paint,clear,reducer,funnels,etc...expensive these days...
Old 10-12-2013, 03:36 PM   #20
mark_ash0426's Avatar
Use a heat gun to remove it as smooth as possible so it stops peeling so much and depending on how bad it is your gonna know wether or not your gonna have to repaint the hood or just fix the small stuff
mark_ash0426 is offline   Reply With Quote
Old 10-12-2013, 04:36 PM   #21
Fader's Avatar
Region: Idaho
I'd agree with the poster that said to remove the decals with a heat gun. Then, I'd wet-sand just that area with 2500-grit to 3000-grit, very gently. I've been cleaning up old touch-ups with the same method, and am getting AMAZING results. If that's a factory paint job, I can't see how the clear-coat could be bubbling that way.
Fader is offline   Reply With Quote
Old 10-13-2013, 03:08 PM   #22
98GTCONV's Avatar
Here's more pics
ID:	132381   Click image for larger version
ID:	132383   Click image for larger version
Old 10-13-2013, 03:58 PM   #23
jduckz5.0's Avatar
Jeez!!! Time for a full paint job..your clear is shot...
Old 10-13-2013, 04:37 PM   #24
*1 anything else is just a temporary fix
Old 10-13-2013, 05:37 PM   #25
98GTCONV's Avatar
Well it's only the right side of hood, driver side fender and driver side pillar. All the rest of the paint looks new. Car was in a wreck so however did the paint job sucks.
Old 10-13-2013, 05:53 PM   #26
jduckz5.0's Avatar
If you cheap out and just paint those pieces now...next year other parts might start coming up too...the money you spend to get it done and match and new decals now you might as well save your money and do the whole car...
Old 10-13-2013, 09:11 PM   #27
98GTCONV's Avatar
What's a good paint job? $2000?
Old 10-13-2013, 09:40 PM   #28
jduckz5.0's Avatar
If you got some car guys around you could ask who is good and does side work.. I'm sure you could find somebody that will do a nice job for $2k...its a simple sand,tape,paint,and wetsand so ask around your area or car shows...
Old 10-13-2013, 10:03 PM   #29
98GTCONV's Avatar
2 g's is a lot. Rather deal with the small spots for now. Maybe paint it if I want to resell. It bothers me, but not enough to drop 2k on it lol
Old 10-13-2013, 10:54 PM   #30
jduckz5.0's Avatar
You could just try wet sand it yourself...tape it off at the edges and spray some clear coat...
10:08 PM
