Installed nee grille on '14 - Mustang Evolution
Old 10-25-2013, 07:06 PM   #1
Crewchief15's Avatar
Installed the Boss 302 grille insert on my '14 but kept the fog lights. I don't mind the fogs, just couldn't stand the chrome pony. I think it turned out well.
Crewchief15 is offline   Reply With Quote
Old 10-25-2013, 09:00 PM   #2
Region: Hawaii
very nice. That emblem looks a lot better than the base mustang one.
lwevert is offline   Reply With Quote
Old 10-26-2013, 07:46 AM   #3
does the mustang just pop off the newer ones ??
Old 10-26-2013, 07:59 AM   #4
Clink's Avatar
Do you have to cut or modify it to keep the fogs?
Old 10-26-2013, 09:13 AM   #5
No, it's actually am entire new grille insert. There's both am upper and lower grille insert. I replaced the upper insert.
---------- Post added at 10:13 AM ---------- Previous post was at 10:10 AM ----------
Yeah, there are tabs on each fog light cut out on the new grille. You have to cut those off in order to retain the fog lights. Once you modify it, you cannot use it to delete the fog lights as the fog light covers will no longer attach.
Old 10-26-2013, 09:26 AM   #6
Originally Posted by crewchief15 View Post
no, it's actually am entire new grille insert. There's both am upper and lower grille insert. I replaced the upper insert.
---------- post added at 10:13 am ---------- previous post was at 10:10 am ----------
yeah, there are tabs on each fog light cut out on the new grille. You have to cut those off in order to retain the fog lights. Once you modify it, you cannot use it to delete the fog lights as the fog light covers will no longer attach.
oh i got you and you added the fogs
Old 10-26-2013, 01:03 PM   #7
No. The GTs come with fog lights in the grille stock. If you look at the front end of a Boss 302, you'll notice that where the fog lights would be, the lights are capped off. They aren't there. The grille I have gave me the option to block out the fog lights, actually removing them and putting covers over where they would be. I wanted to keep the fog lights and use the Boss 302 grille. If that makes sense.
Old 10-26-2013, 05:40 PM   #8
cheelyb09's Avatar
Looks good.
Old 10-26-2013, 05:41 PM   #9
that's what I meant you added the lights to the boss grille
10:15 PM
