Grrrrr - LED troubles - Mustang Evolution
Old 11-15-2013, 05:01 PM   #1
Always broke's Avatar
Hey I installed LED light bulbs in the front of my 2007 GT. Of course the hyper flashed so I installed a set of LED resistors and they still hyper flash! WTF.... The weird thing is the hazards are fine. Any ideas would be great.
Always broke is offline   Reply With Quote
Old 11-16-2013, 06:12 AM   #2
Mlarv5's Avatar
Yup what resistor set up did you use. There are two ways of doing this one is with resistors at each bulb and the other has a resistor setup in the flasher relay. The 4 ways working draws enough current to make them flash correct. Your problem sounds like it is the resistor setup you are using is not working correctly to the LEDS you have.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 11-16-2013, 08:37 AM   #3
I used two white ceramic type and wired them correctly I believe. One on each side.
Old 11-16-2013, 09:39 AM   #4
Mlarv5's Avatar
I would double check the connections and double check the wiring of them. It really is pretty simple to do but really easy to make a mistake. What instructions did you use to do this?
Old 11-16-2013, 09:46 AM   #5
The ones on the back of the package with those quick splices. The LEDs are PUTCO brand
Old 11-20-2013, 12:44 PM   #6
Today was the first time I had an opportunity to doublecheck my work. I found that the quick splices providedI simply missed a wire on both sides I pulled it apart redid my connections and everything is perfect.
Old 11-22-2013, 08:00 AM   #7
Mlarv5's Avatar
I love it when a plan comes together. Glad they are working
Led trunk light bars. Greg3 Mustang Audio & Video 19 06-17-2013 10:52 AM
LED Foglights robb15033 General Car Discussion 1 01-16-2013 02:00 PM
LED Dash upgrade jroth823 Classic Mustangs 17 02-29-2012 06:38 AM
12v led light hook up 99 gt 99redgt 1996-2004 Mustang GT 16 02-01-2012 07:15 PM
Roush led boost gauge help? Rapinator126 Roush Mustang 0 01-04-2012 11:12 PM
» Members Mustangs
Ariel
JSHOOT3
8-Ball
Butch
Add your Mustang
08:28 AM
