2014 Mustang GT - Will these LED's replace my DOME light? - Mustang Evolution
Old 12-18-2013, 12:22 PM   #1
194 LED Bulb - 1 SMD LED Wedge Base | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs
Will these be able to replace my dome lights? Also are these compatible to replace the license plate lights in the rear as well?
Thanks in advance.
seville is offline   Reply With Quote
Old 12-18-2013, 06:39 PM   #2
SixBanger's Avatar
It will indeed. I got similar LED dome lights. Simple install btw.
Just pull the dome off of the ceiling. REALLY pull, it's held up there with metal clips and will make a loud metallic "ping" sound when they come loose. Then you can pull the lights out through of the back of their housing to replace them.
Alternatively, you can use a pocket knife or flat-head screw driver to pry the lenses off of the dome and just pull the stock bulbs out of their housing that way (this is how I did it). Don't worry about breaking the lenses as they are flexible, but take your time.
Whichever floats your boat.
Here's the link to the ones I bought in case you aren't sold on the ones you've found. They are BRIGHT. As in "daylight-in-your-car-at-night" bright. 2005-2014 Ford Mustang Dome & Map Light LED Upgrade (W/built in Resistor) Double the light
SixBanger is offline   Reply With Quote
Old 12-19-2013, 10:11 PM   #3
SixBanger's Avatar
They'll work in the dome. Not sure about the license plate lights...
2014 mustang
06:04 PM
