Paint peeling under the Hood - Mustang Evolution
Old 01-25-2014, 10:34 AM   #1
cmd
cmd's Avatar
My 2012 Gt has the paint peeling along the seam on the front edge of the hood. It is flaking off, and can be removed with my fingernail. Anybody else seeing this? Dealer says could be rust, but looks like bad paint adhesion.
cmd is offline   Reply With Quote
Old 01-25-2014, 10:45 AM   #2
fairly common issue since 05, when Ford switched to aluminum skin hoods. get them to sand it down and repaint it before it becomes a bigger problem.
Old 01-25-2014, 10:59 AM   #3
cmd
cmd's Avatar
Thanks. I cleaned it up and touched it up. I was just worried when he said rust!
Old 01-25-2014, 04:27 PM   #4
It's a galvanic corrosion between the two dissimilar metals. Happens very often. Same reason you can use steel tie downs for copper pipe in your house.
Old 01-28-2014, 02:32 PM   #5
jek57's Avatar
I had the same problem with my 09.What i did was sand it down i bought some por-15 and sealed it with that so far it has stopped it ....what it is used for it to stop rust it drys rock hard .So far it has worked for me ..check it out u can buy it on amazon
jek57 is offline   Reply With Quote
Old 01-29-2014, 11:11 AM   #6
This is a problem with a lot of the new stangs with aluminum hoods. Ford didn't properly seal where the two metals meet so corrosion will be the result. Contact your dealer and report it, if it gets worse you my need the hood repainted.
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Baldeagle is offline   Reply With Quote
New 2012 Mustang with factory paint flaws meast553 2011-2014 Mustang GT 12 10-30-2016 05:36 PM
restoring paint scottiep101 Mustang Paint, Appearance & Detailing 5 06-15-2012 08:59 PM
Time to peel the hood... Topless04GT Mustang Paint, Appearance & Detailing 0 02-09-2012 06:23 PM
hood pins or no hood pins? + 87,89,93 octane gas andyr421 1996-2004 Mustang GT 14 11-19-2011 09:15 PM
Which hood? caraccioloc 2005-2010 Mustang GT 23 10-07-2011 05:54 AM
09:15 PM
