Touch up ideas for rear aluminum MRT louver. - Mustang Evolution
Old 04-01-2014, 10:18 PM   #1
Ali Tabooger's Avatar
I've recently found a few chips on my aluminum rear window louvers. Anyone have any ideas or thoughts on touch up?
Ali Tabooger is offline   Reply With Quote
Old 04-02-2014, 08:20 AM   #2
OfficialMakkyZ's Avatar
I don't have your answer, but I have a semi-related question, I figure someone can come on here and answer us both instead of me having to make a whole new thread for it.
I plan on getting AM's MMD Rear Louvers. What's the difference between these and the aluminum ones? Which do you think look better? Are the MMD's pretty tough? (against weather and etc)
Check out my garage:
http://www.mustangevolution.com/forum/f376/t351203/
OfficialMakkyZ is offline   Reply With Quote
Old 04-02-2014, 11:14 AM   #3
Foxone's Avatar
Is this a black painted louver? Id go with some matte engine enamel. It comes in a spray can, but you can spray it onto a small paintbrush and dap it on the chips. be fast though, matte coats set up quick.
2015 GT Premium....
Foxone is offline   Reply With Quote
Old 04-02-2014, 11:56 AM   #4
Some like the abs plastic look and others prefer the aluminum. I'm not sure but I believe you need to use a ratchet to remove the ABS from the window for cleaning and the whole thing comes off. The aluminum is hinged, has 2 clips at the bottom, and uses prop rods to hold it up for cleaning.
Some people have complained about the aluminum rattle. Ive also heard complaints about the ABS rattle. Ive never had that problem with speeds over 150... They've been solid.
My only concern with ABS would be with sun fade over time. The aluminum ones are powder coated and still look brand new... except for those few chips from flying rocks... Someone was blowing debris in to the street with a massive parking lot blower.
It really depends on your preference. Plastic look vs aluminum look. Ive also seen some painted to match the car.
Old 04-02-2014, 12:01 PM   #5
Thanks Fox. Yes, its the painted powder coat kind. Ill give that a try.
Old 04-03-2014, 02:19 AM   #6
Ntbruncie's Avatar
Take them off and have them powder coated. That what I was going to do with the set I had.
Ntbruncie is offline   Reply With Quote
Old 04-04-2014, 08:43 PM   #7
Bear376's Avatar
I think the MRTs are a satin finish, not a matte black. You may want to check with a body shop and get a quote. If you are good at spray painting, a can of good automotive paint in a can may be your best bet.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
MRT Rear window Louver Starsky007 Mustang Paint, Appearance & Detailing 4 10-10-2013 07:52 AM
rear window louver advice??? br10301 1996-2004 Mustang GT 14 04-27-2012 01:10 AM
Rear window louver Blackedout Pre-2005 V6 Mustang 8 04-29-2011 09:01 PM
79-93 Be Cool Aluminum 2-row radiator w/ aluminum cap fast64 Mustang Parts for Sale and Wanted 6 07-22-2009 02:14 PM
badass v6 mustang by MRT... (mrt cherry 6T6) dark The Bar 17 04-02-2006 09:44 PM
10:08 PM
