Fogged up headlights help. - Mustang Evolution
Old 05-21-2014, 07:24 PM   #1
Mike1beck's Avatar
Region: Arkansas
I have a 1999 mustang with the headlights fogged up. What can I do to fix this short of buying new headlights
Mike1beck is offline   Reply With Quote
Old 05-21-2014, 10:07 PM   #2
OfficialMakkyZ's Avatar
I tried every de-fogger available on the market, none worked. I eventually just bought new headlights.
Check out my garage:
http://www.mustangevolution.com/forum/f376/t351203/
OfficialMakkyZ is offline   Reply With Quote
Old 05-21-2014, 10:08 PM   #3
Mike1beck's Avatar
Region: Arkansas
Well crap that sucks..
Old 05-22-2014, 07:20 AM   #4
Mosified's Avatar
American Muscle has the nicest selection of headlights. Secondly, Craigslist auto parts usually has headlights for your year cheap.
Old 05-22-2014, 11:28 AM   #5
MasonStacks's Avatar
I actually used goo gone and it worked well
MasonStacks is offline   Reply With Quote
Old 05-22-2014, 11:43 AM   #6
Mike1beck's Avatar
Region: Arkansas
Really? I might try that first.
Old 05-22-2014, 11:46 AM   #7
Yeah it worked on three cars that I have tried it on, and for serious stuff that would not come up try xylene but not to much of it, don't want it to eat the lense.
Old 05-22-2014, 11:47 AM   #8
Mike1beck's Avatar
Region: Arkansas
Alright thanks!
Old 05-22-2014, 11:58 AM   #9
No problem man
Old 05-22-2014, 12:00 PM   #10
Mosified's Avatar
Fogged from the inside or outside? Toothpaste works and MOTHERS also has compound (3 stage kit). If its from the inside then the seal is broke
Old 05-22-2014, 12:02 PM   #11
Mosified's Avatar
Get them nice and smooth and High Gloss Acrylic Clear makes them nice and shiny. Followed by super fine wetsanding and Rub & Buff them out. Like new
Old 05-22-2014, 12:04 PM   #12
Mosified's Avatar
Be careful with the Goo Gone. Mine got chunky and are now uneven (aligatored) Someone before must have put something on the surface that didnt agree. Lol
Old 05-22-2014, 12:05 PM   #13
Mosified's Avatar
Acrylic Clear coated.
Old 05-22-2014, 02:06 PM   #14
Mike1beck's Avatar
Region: Arkansas
No problem man
Well I got to looking and I can't figure out how to take the lense off the headlight. I tried wedging it but I felt like I was going to break it. How do I get it off?
Old 05-22-2014, 02:16 PM   #15
Mosified's Avatar
Google video - remove headlights 99 mustang
Old 05-22-2014, 02:17 PM   #16
Mosified's Avatar
How to videos come up. There are 2 pins in the top of them holding them in. You have to twist them out and they pull up.
Old 05-23-2014, 12:44 PM   #17
Don't twist em. Pull em straight up. I tried goo gone and it sucked
Old 05-23-2014, 01:25 PM   #18
john.petr0's Avatar
if you go to your local auto shop they actually have a lense cleaner. it works real good! and it's cheap
john.petr0 is offline   Reply With Quote
Old 05-23-2014, 01:30 PM   #19
hd85's Avatar
I used some 10 dollar turtle wax lens restorer and it cleared mine up. They were foggy yellow and now there pretty clear. Cheap and easy.
Sent from my HTC6435LVW using Mustang Evolution mobile app
hd85 is offline   Reply With Quote
Old 05-23-2014, 01:31 PM   #20
Mike1beck's Avatar
Region: Arkansas
Well the people that had the car before me glued the lense onto the headlight so I might just buy some new headlights
Old 05-23-2014, 03:18 PM   #21
Mosified's Avatar
+1
Old 06-17-2014, 02:16 AM   #22
Toothpaste worked for me
Sent from my SPH-L710 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 06-17-2014, 03:19 AM   #23
bucko's Avatar
That explains it. On an F-150 forum I used to frequent, the trick to making a set of F-150 headlights to be like the Harley-Davidson edition (black-out) was to remove the headlight buckets, heat them at 350 degrees in the oven (to soften the sealant/glue), pull off the lenses, paint the insides, then re-seal with silicone.
Problem was, if you did not get off ALL the old sealent first, the re-applied sealint would not allow the lenses to be perfectly sealed, and the first rain or vehicle wash would get water into the inside, and they would fog.
Never, never drill holes into a headlight housing in thinking this will vent the headlight housings. They already have a vent tube, so additional holes only act to allow water to enter the housings and aid in the fogging.
And beware of low cost headlight replacements. There's a lot of cheap stuff out there that also fogs up. Get quality replacements.
Old 06-23-2014, 10:11 AM   #24
Bear376's Avatar
I am helping restore a 2000 and a set of headlights are cheap. The plastic lenses will only last so long without being cleaned on a regular basis Once they have gone past a certain point, they will not clean.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 06-23-2014, 10:17 AM   #25
Mosified's Avatar
High Gloss acylic clear restores them nicely
Old 06-23-2014, 11:31 AM   #26
Mosified's Avatar
Wet sanding them between 4-5 coats is KING!!
HELP! Need help raxiom headlights fordfan100 Mustang Paint, Appearance & Detailing 19 02-08-2017 03:49 PM
Changing a 1986 Mustang headlights into looking like a 1987 mustang headlights? Rayman 1979-1995 Mustang GT 1 12-17-2011 03:49 PM
Need Advice. Mustang Headlight Fogged Up. AllanBane 1996-2004 Mustang GT 3 10-17-2011 06:37 PM
Need Advice After Headlight Fogged Up DarnellWade General Mustang Discussion 3 03-26-2011 09:20 PM
Fogged up headlights Testicleez Mustang Audio & Video 10 03-22-2004 07:38 AM
09:09 PM
