Detailing my baby - Mustang Evolution
Old 06-24-2014, 08:11 AM   #1
Sportsman's Avatar
Detailing my baby
To all you detainers out there... I have a question... How do I restore my black car to that glossy lustrous shine that makes me want to mmmmm... You get the point. It's a 2014 black v6 that I have recently neglected ... I know... I'm canadian and looked at products from chemical guys but shipping is way to much.... I've recently purchased mequires smooth clay surface kit and turtle wax jet black kit.... What I'm asking for is, is there anything else I need? Also the order in which to do things? I really want to get into a routine . Also, since mine is a base, are there any interior products you'd suggest?
As a reference here's what's in those kits
Black pre wax cleaner
Black carnauba wax
Spray detailed applicators
For the mequires
2 clay bars
Quick detailer and microfibre
Thanks in advance guys and gals
A
Sportsman is offline   Reply With Quote
Old 06-25-2014, 09:51 PM   #2
JoeyM91's Avatar
Black carnauba wax
For the mequires
2 clay bars
A
What are the issues on your paint exactly? Swirls? Bugs? Dust?
Old 06-25-2014, 11:08 PM   #3
Loc: Austin,TX
Clay,machine polish,wax. Buy a DA polisher from Harbor Freight or a Porter cable or a Flex. Its pretty much impossible to screw up your paint with a DA polisher. If you are new to this check out "Junkman" on youtube. He is crazy,talks to much but he will break it down for the rookies. He's legit.
https://www.youtube.com/results?sear...kman+detailing
Old 06-26-2014, 06:02 PM   #4
Sportsman's Avatar
Bugs dust and minimal swirls.
---------- Post added at 06:02 PM ---------- Previous post was at 06:01 PM ----------
Appreciate the link. Will check that out asap
Old 06-26-2014, 07:18 PM   #5
JoeyM91's Avatar
Junkman is pretty good for how-tos. If you want to step up to something more professional there is also AMMO NYC here: ammonyc.com.
Depending on how nutty you want to get, there's lots of options. I'll just list my normal routine and products:
Wash on the weekends. First, rinse well to get the big stuff. Next, foam gun with DP Xtreme Foam on the entire car. RInse thoroughly again.Two bucket method hand wash with buckets that have grit guards (important). Microfiber mitt, and more of the DP wash.
Wash from the top down with plenty of suds. Get the painted surfaces first and then move to any unpainted plastics. Then Glass, and lastly your wheels. (best two have two mitts, one for painted surfaces and glass and another for the wheels).
Follow up the wash mitt with some good wheel cleaner (Simple Green works well, but it depends on what type of wheels you have) and brush to get rid of the crud.
Then one final good rinse on everything. Drying is important, this is the area most people introduce the most swirls and defects:
I first use a leaf blower (yes a leaf blower) to blow away the water as much as possible so my cloths touch my paint as little as possible. It's important that the leaf blower be electric because a gas powered one will get exhaust all over your car.
After I've gotten that done well. (It usually gets rid of about 90% of the water) I grab my best clothes Zano Borderless Blondes (Borderless very plush towels so there is nothing with an edge to cause swirls). I spray both sides of the towel with my detailing spray (Gary Dean's Infinite Use Detail Juice, it's a concentrate product you mix with distilled water. It's AMAZINGLY good and you get a good 60+ Gallons of total detail spray out of a $40 sized bottle)
Dry everything down carefully and gently. Do NOT put pressure down. I only use the Zano's on painted surfaces and glass. For the wheels a normal microfiber cloth is fine.
Then for the glass, I recommend Stoner's Invisible Glass with a good waffle-weave microfiber cloth.
Then, just to get rid of any waterspots you might have missed, lightly mist each panel with the detail spray and follow it up with some gentle wiping with the Zanos.
Now.....The Engine Bay! One of the most overlooked areas. First, make sure your fuse box is securely shut, put a plastic bag over your filter if you have a cold air intake and another plastic bag over the alternator (down and to the right facing your engine). Make sure everything is secure and then spray everything down with the hose (Don't use a powerwasher). Then with a good medium sized brush (Mother's makes a good brush set) and some SImple Green, spray everything down with the simple green really well and let it settle. Then agitate everything by scrubbing with the brush all over. Once you're done, let it sit for a couple of minutes and then rinse everything off really well.
Let it drip dry a couple of minutes then follow it up with the leaf blower as best you can in the entire bay. Then you can remove the plastic bags and then blow the filter and alternator off just in case.
Hand dry what you can with a microfiber cloth, then turn on the car and let it warm up, it'll help dry everything off after that.
Got all that?
Now for swirls:
Swirls are caused by grinding dirt or rough surfaces on your paint. They're microscopic gouges in your clearcoat. So what you have to do is polish. What polishing does is edges away your clearcoat to level everything off. This is fractions of Mils of clearcoat, so it doesn't hurt the paint.
I would recommend watching Junkman and AMMO NYC to get familiar with the technique and then a good Dual Action Polisher to get started is Griot's Garage DA. Good power, affordable and reliable. Pads are a dime a dozen, both Junkman and Ammo NYC give suggestions, those are good to go with.
Now for your products: Meguiar's Professional series is a solid choice namely M105 (for deeper swirls and more neglected paint) and M205 (lighter swirls and to finish). However, I prefer Menzerna FG400 (a good all-round product).
Finally, for dust in-between washes: An Original California Duster is a good option. It's exactly what it sounds like, a duster for your car. But the most important thing to remember using it, do NOT press down or you WILL introduce swirls. Use a very gentle sweep where the fibers just barely touch your paint.
For any bird poop, smudges, debris etc. Never wipe your paint without using detail spray, or you will introduce swirls.
For Waxing/Sealants: I prefer Klasse for my base layer (a good old-school synthetic that lasts long and has a clear wet look), then I top that with 1-2 layers of Pinnacle Souveran ( Pure Carnauba, doesn't last as long but gives a nice warm glow)
Remember to clay your car prior to sealing/waxing. Mother's makes a good starter kit for it. Both junkman and AMMO have how-tos on how to use it.
My biggest piece of advice would be to learn the techniques completely and FOLLOW DIRECTIONS ON THE BOTTLES.
Old 06-26-2014, 07:43 PM   #6
Loc: Austin,TX
Don't look past the Junkman because he is professional as they get. He travels all over and details $100K + vehicles. He dumbs some of the videos down so that rookies can understand which is great. Everything is the above post sounds great but the only things I would do differently is start with the engine first and make sure it's cold,do my wheels before paint,do a sheet rinse before the leaf blower and I would never touch my paint with a Cali duster. Many people swear by the Cali duster but its just not my thing. I will instant detail (with veeeeeery light dust) or just a straight wash before picking up a Cali duster. If you are new its gonna be all about trial and error......it's the only way to learn. Good luck and remember,have fun when doing it!!
Old 06-26-2014, 07:51 PM   #7
Larry from AMMONYC is great at breaking stuff down also. Another one of those guys that travels all over and details million dollar cars. His YouTube is AMMONYC and has tons of vids up.
Old 06-26-2014, 08:43 PM   #8
JoeyM91's Avatar
Yup, trying to put everything I do down I did miss a couple things lol.
The sheeting rinse is good for your final rinse after you spray everything down. (Take the sprayer off the hose and start from the top down and let the water "sheet" down. This rounds up a lot of the small water droplets)
Junkman is good, no doubt but Larry at AMMO handles a lot of Exotics, so I figure "Hey! If it's good enough for a Ferrari F40, it's good enough for the Stang "
Old 06-26-2014, 08:45 PM   #9
Detailing my baby
Exactly
Old 06-26-2014, 09:15 PM   #10
Loc: Austin,TX
Junkman doin it up Lambo style in Flordia.
Old 06-28-2014, 08:13 AM   #11
Rcmonaco's Avatar
Black carnauba wax
For the mequires
2 clay bars
A
I used Mothers Clay Bar Kit and the Mothers Brazilian carnauba wax on my 14 year old paint job and it turned out FLAWLESSClick image for larger version
Name:	ImageUploadedByMustang Evolution1403964807.386707.jpg
Rcmonaco is offline   Reply With Quote
Detailing Guide STEVE Mustang Audio & Video 27 03-16-2005 08:49 PM
Spent 3.5 hours detailing my truck, results inside sonic04edge Pictures and Videos 7 11-10-2004 07:04 PM
New Detailing Thread. (Wax, Polish, Wash, etc...) greenflash00 Mustang Audio & Video 43 07-03-2004 12:07 PM
Heard of some good car detailing stuff Blue232 Mustang Audio & Video 5 02-02-2004 12:00 AM
SWEET!! I GOT A JOB DETAILING CARS!! OneBadPony00 Mustang Audio & Video 5 07-23-2003 10:35 AM
03:01 AM
