Paint runs - Mustang Evolution
Old 07-09-2014, 10:48 PM   #1
Tangtang2.0's Avatar
Paint runs
So after my dad's friend painted my car a couple weeks ago I noticed some runs I know you can sand em down but what do you do after to get rid of the scratches
Tangtang2.0 is offline   Reply With Quote
Old 07-09-2014, 10:59 PM   #2
Hellish Horse's Avatar
Use Meguire's Ultimate Compound & follow with waxing. The Meguires will get rid of the scratches & bring back the shine.
Hellish Horse is offline   Reply With Quote
Old 07-09-2014, 11:03 PM   #3
alright so sand > compound > wax?
Old 07-09-2014, 11:05 PM   #4
Do your final sanding with 1000 grit and then buff it out with a polishing compound.
Are the runs in the base coat or the clear coat?
Old 07-09-2014, 11:05 PM   #5
JoeyM91's Avatar
Depends on how severe it is. Obviously, to get rid of the runs you start by wetsanding with the thicker grade and then work your way down to finer grades. As you keep stepping down to finer and finer grades (the most I saw available was 5k, but that might be hard to find), it will leave less and less marring.
If you can get it down to about a 3-4k you can use a light polish with a DA and normally take that marring out.
Old 07-09-2014, 11:12 PM   #6
I use 1500, then 2000 & then 2500 grit. Then Meguires & Wax. Walmart has the Sandpaper / Polishing Cloth in the Automotive Dept. You will not find it in the Paint Dept.
Old 07-09-2014, 11:13 PM   #7
Thanks everyone
Old 07-09-2014, 11:15 PM   #8
Where do you find that fine of sand paper Joey? I was just at the auto body supply store in my area and, I don't think that they had anything that fine.
Old 07-09-2014, 11:15 PM   #9
Only place I found to buy 5000 Grit was a Jewelery Supply House as they use it to polish Jewelery.
Old 07-09-2014, 11:18 PM   #10
JoeyM91's Avatar
Here's a place. As I said it's TOUGH to find. Doubt any parts stores would carry it. The finest I've found in normal chain stores was 3k:
3M Company 30189 2-3/4 X 5-1/2 5000G FOAM SHEET - JMC Automotive Equipment
Old 07-09-2014, 11:23 PM   #11
Same Brand as I get from the Jewelery Supply. 3M, 9"x11" sheet of 500 Grit is $1.99 ea.
They call it Polishing Paper once the Grit Passes 3000 grit.
Old 07-09-2014, 11:23 PM   #12
JoeyM91's Avatar
Appears they make up to 8000 for woodworking applications. Pretty sure that would be like sliding a piece of paper across it though
Micro Mesh 8000 Grit 6 X 12 Sheet (ea) | Klingspor's Woodworking Shop
Old 07-09-2014, 11:23 PM   #13
Interesting.
Lol.
I'm still in the paint removal and body repair process on mine so I'll let you guys who have some recent experience and actually know what the hell your talking about lead the the way...
Thanks Joey!
Old 07-17-2014, 09:35 AM   #14
Semerollin's Avatar
Damn 8000 is like using news paper to clean windows with.
Semerollin is offline   Reply With Quote
Engine runs, but hesitate/misfire jaynez31 Pre-2005 V6 Mustang 11 01-17-2006 05:30 PM
Insurgent Sniper takes down 1 soldier a shot and runs? Seph The Bar 17 01-13-2006 08:17 PM
03 5spd runs 14.47@90 w/ bolt ons??? BrooksPS Pre-2005 V6 Mustang 13 03-09-2004 08:10 PM
05 Cobra runs 11.62 @ 126, holly mother!! Autobadges.com The Bar 32 02-10-2004 11:43 AM
After 3 weeks it runs. slow232 The Bar 13 08-17-2003 06:10 PM
06:16 AM
