Exhaust tip polish - Mustang Evolution
Old 01-04-2015, 04:58 PM   #1
MattsGT's Avatar
Exhaust tip polish
I have Magnaflow exhaust tips that are in need of a cleaning/polish. Can anyone provide some guidance on what works well?
Thanks
2002 GT 5Spd
MattsGT is offline   Reply With Quote
Old 01-05-2015, 09:33 AM   #2
Darth Paul's Avatar
Belgom Alu
Sent from somewhere near the center of the Milky Way
Darth Paul is offline   Reply With Quote
Old 01-05-2015, 11:10 AM   #3
MattsGT's Avatar
Thanks Darth Paul. Love your screen name btw.
2002 GT 5Spd
Old 01-05-2015, 11:12 AM   #4
WJBertrand's Avatar
Blue Magic is my fave...
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 01-05-2015, 11:21 AM   #5
MattsGT's Avatar
I have seen some articles online that use the polish as the final step after steel wool or something similar. Are you just using the polish or is that just one step in the process?
I imagine that it depends on the condition of the tips but mine are not excessively tarnished.
2002 GT 5Spd
Old 01-05-2015, 11:31 AM   #6
24kmach's Avatar
Happich Simichrome Polish - Metal Polish - Only $7.99! Or Griot's Chrome polish.
24kmach is offline   Reply With Quote
Old 01-05-2015, 11:40 AM   #7
JoeyM91's Avatar
Well there's going to be a difference if you have actual chrome tips or polished stainless. Most are going to be polished stainless. Actual chrome is crap.
Old 01-05-2015, 11:48 AM   #8
MattsGT's Avatar
Mine are the polished stainless.
2002 GT 5Spd
Old 01-20-2015, 08:29 AM   #9
Waylap1's Avatar
Region: New Hampshire
000 steel wool. I used to a motor cop (Harley) lots of chrome and stainless to keep looking nice and the 000 wiped everything off and polished it. Even stuff that accidentally melted to the hot pipes. Works fast too. If you combine it with chrome polish even better.
Waylap1 is offline   Reply With Quote
Old 01-20-2015, 09:13 AM   #10
Region: Nevada
I've been using Nevr-Dull since the 1970's, easy to use and works well with all polished metals, aluminum, stainless steel, brass, etc.
2014 SGM GT, 300A base coupe, 6R80, daily driver.
silverstate777 is offline   Reply With Quote
Old 01-20-2015, 12:39 PM   #11
Getn off's Avatar
Agreed. Been using since the 70s on cars, boats, bikes, and airplanes also, and it is fantastic stuff.
Troy
Getn off is offline   Reply With Quote
Old 03-08-2015, 12:48 PM   #12
Nevr-dull works well if they are not too bad. If you have a lot of layered black carbon I will use the 000 stainless steel wool first but i keep it well lubricated with a soapy water solution so as not to scratch the finish. Then try the Nevr-dull or Mother's metal polish.
Sent from my ASUS Transformer Pad TF700T using Mustang Evolution mobile app
Justin72 is offline   Reply With Quote
Old 03-15-2015, 08:27 PM   #13
Famine's Avatar
Region: South Dakota
Any of them work. I love mothers. If there is rust, you can start by wet sanding prior to.
Famine is offline   Reply With Quote
Old 03-16-2015, 02:58 PM   #14
Second this!
binly is offline   Reply With Quote
Old 03-16-2015, 04:28 PM   #15
WJBertrand's Avatar
And if you have burned on stains try a little (this will sound nuts but it works) Easy-Off oven cleaner. Warm up the pipes a bit, turn off the car, spray the cleaner on, (don't get it on your paint!) then let it sit a while, 15-20 minutes or so. Most stain (not corrosion) will just wipe right off with a damp rag or sponge. Rinse off the surfaces and then don't forget to apply some polish as a finishing step.
-Jeff-
Ventura, CA
Old 03-16-2015, 08:45 PM   #16
Peterzinyou's Avatar
0000 steel wool and Croftgate tireshine.
Sent from my SM-N900T using Mustang Evolution mobile app
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 03-22-2015, 07:50 PM   #17
cb619's Avatar
Region: Nevada
The steel wool 000 works great, I've used the mothers power ball afterwards with mothers all metal polish with good results.
Sent from my SGP561 using Mustang Evolution mobile app
cb619 is offline   Reply With Quote
exhaust
Cut exhaust tip so can't see it under rear bumper? brooksyx Pre-2005 V6 Mustang 7 02-20-2013 10:33 PM
One exhaust tip a little off after Boss exhaust install mmike87 2011-2014 Mustang GT 6 09-21-2012 07:42 PM
exhaust tip question shsfresh87 General Mustang Discussion 1 12-20-2011 03:28 AM
Exhaust tip questions WhiteStang99 Mustang Audio & Video 23 07-29-2005 02:10 PM
To Tip or not to Tip.... Ibanezplayer272 Pre-2005 V6 Mustang 15 04-28-2005 09:29 PM
12:33 PM
