Exhaust tips paint? - Mustang Evolution
Old 01-17-2015, 07:22 PM   #1
syndicate's Avatar
Exhaust tips paint?
Can i plasti dip my exhaust tips black or will the heat destroy the dip? Is there any other kind of paint/coloring that i can make them black with? thanks
syndicate is offline   Reply With Quote
Old 01-18-2015, 10:28 PM   #2
JoeyM91's Avatar
Plastidip will crack and peel off due to the heat. If you really want to paint them ceramic coating is your best bet, or a quality powdercoat.
Old 01-18-2015, 11:18 PM   #3
DiESeven's Avatar
I plastidipped my borla s type tips roughly 7000 miles/ 6 months ago and they still look the same as day 1.
Old 01-20-2015, 08:24 AM   #4
Waylap1's Avatar
Region: New Hampshire
Barbecue black spray paint from Walmart or homedepot has worked well for me. It's made for touching up your outdoor grill.
Waylap1 is offline   Reply With Quote
Old 01-20-2015, 09:14 AM   #5
fenixignition's Avatar
you might be able to get away with the plastidip. the tips dont get too rediculously hot like the cats or manifolds, but hot air is blowing through it still. If you have access to a laser thermometer, i would check the temps of the metal at different times just to see what numbers you get.
2002 GT 5sp. 16x,xxx miles
Old 01-20-2015, 10:23 AM   #6
kona stang707's Avatar
How much do you think it would be to powder coat the tips?
kona stang707 is offline   Reply With Quote
Old 01-20-2015, 11:34 AM   #7
Have used the BBQ High Temperature paint to paint muffler/tips black and a 3/8" white ring on the tip and they still look great after 5,000 miles
GTAHVIT is offline   Reply With Quote
Old 01-20-2015, 11:39 AM   #8
Waylap1's Avatar
Those look good. Btw what stripe size is that? 10" wide with 2" gap?
Old 01-20-2015, 11:57 AM   #9
Yupper; here's a front view of the stripes; taken at the in-field of the Atlanta Motor Speedway:
Old 01-25-2015, 12:41 AM   #10
allworknoplay's Avatar
Plasti-dip is the best thing to try first most cars it will work fine for tips but use 6 plus coats
I have my tips and wheels dipped on my hummer and that went through very rough terrain and my exhaust more than likely ran higher temps from using 4low.
Sent from my SM-T310 using Mustang Evolution mobile app
2007 GT: Vista blue 5spd 93 Tune
allworknoplay is offline   Reply With Quote
Old 02-05-2015, 02:44 AM   #11
Im curious lol, can you take a picture of them
03redzo6 is offline   Reply With Quote
Old 02-05-2015, 03:31 AM   #12
The heat is probably going to harden it sorta, so if anyone does this and later wants to remove it and realizes that its not peeling off easily, the trick is either respraying it with more plastidip, wd40, or lacquer thinner. All will help dissolve or loosen plastidip.
Sent from my LG-D800 using Mustang Evolution mobile app
Old 02-09-2015, 01:44 PM   #13
Look up dipyourcar and they make a dip remover spray. I personally had no problem removing it off mine. again tho do many coats, more coats the easier to remove!
Old 02-10-2015, 04:18 PM   #14
aleXXXps's Avatar
I used a high temp Duplicolor engine spray paint on my tips on my old Ford Focus. Within 2 months, most of it cracked and peeled off and looked terrible.
aleXXXps is offline   Reply With Quote
Old 02-13-2015, 07:56 AM   #15
The grill paint will probably be the way to go.
2011 Kona blue GT.
exhaust
Tips for touch up paint Jvibe92 Mustang Paint, Appearance & Detailing 9 04-13-2015 07:19 PM
Road paint removal tips? Saleen90 2011-2014 Mustang GT 8 10-11-2014 05:42 PM
Tips for taking care of matte paint 91MustangNSB Mustang Paint, Appearance & Detailing 1 08-04-2013 01:54 AM
To paint or not paint carbon fiber poloka 2011-2014 Mustang GT 11 08-18-2012 10:20 AM
SLP Tips and stock tips from 98 Cobra SVT_Rob Mustang Parts for Sale and Wanted 7 08-10-2004 09:08 PM
03:04 AM
