Sand curb rash + Plastidip? - Mustang Evolution
Old 04-08-2015, 09:55 PM   #1
Vystrel's Avatar
I got 3 wheels with curb rash and it's been bothering me every time I look at the car. Wheel refinishing seems to be expensive and my 19in GT wheels have curved lines in the silver paint that would be impossible for me replicate. I know what is commonly done is that curb rash is sanded, maybe add some bondo and sand again to even surface, then finally paint. My problem is I will not be able to match the silver paint so I have been considering plasti dipping them entirely.
Either I just sand the curb rash and leave it bare silver, or all dip. Any suggestions would be appreciated.
Black dip compared to one with a coat of glossifier.
Aluminium dip with glossifier.
2011 3.7L Ingot Silver
Vystrel is offline   Reply With Quote
Old 04-08-2015, 10:33 PM   #2
I just plasti dipped my curb rash without sanding and I can't tell it was ever there unless I'm about two inches from the wheel. Honestly forget which wheel it even was. If it doesn't work for you just peel it off
binly is offline   Reply With Quote
Old 04-09-2015, 06:54 AM   #3
Region: Rhode Island
I have the same problem and I plasti dipped my rims black with silver metalizer and then the clear coat over it. They came out kind of like a gunmetal gray. You can barely notice the rash and there was a LOT of curb rash
ID:	179541   Click image for larger version
2014 mustang v6
19" mustang premium wheels
gt500 spoiler(not installed)
jlt intake
sct tuner but no tune since it will void my warranty (lame)
jmackinn01 is offline   Reply With Quote
Old 04-09-2015, 07:38 AM   #4
Vystrel's Avatar
They look good, I didn't like plastidip because of the flat black look it has, but some Metalizer or glossifier should fix that. Black would probably look better on these wheels than aluminum, thanks for pics and help
Old 06-04-2015, 06:55 PM   #5
I have never used plasti dip but like the way your wheels look. Do you have to remove the tires from the rim or the wheels from the car to plasti dip the rims? Or can you mask off the area and spray?
tucsondivots is offline   Reply With Quote
Old 06-08-2015, 08:10 AM   #6
These were my spare set of wheels and tires so they were already off the car when I sprayed them. I used index cards around the wheel lip to protect the tires from getting spray on them. The dip will come off anyways even if it gets on the tire but I wanted to spare myself a little time decided to cover them.
When I sprayed my rims with Plasti dip they just came out with the metalizer. Since then they have added WAY more products to make your wheels stand out. I plan on spraying my wheels with a gunmetal pearl and put some clear gloss over it.
2014 mustang v6
jlt intake
Old 06-19-2015, 05:07 AM   #7
20prima10's Avatar
It's sad to see so many people hitting curbs. I've never understood that.
20prima10 is offline   Reply With Quote
Old 08-25-2015, 11:13 AM   #8
Vystrel's Avatar
Really late reply, but I bought the wheels off craigslist for cheap with 3 already lightly curbed. And guess what I just did? Curbed the 4th going to my banks drive through ATM thats barely wide enough for a smart car
Oh well, sanding and dipping is probably how I'm going to go until I can get an all new set of wheels.
Old 08-26-2015, 11:02 AM   #9
20prima10's Avatar
Sand it smooth fill with bondo and re sand then when it's perfect. Plastidip it or sand the whole wheel and paint it the right way .
2013 pp mca 3.7 glass roof
2.5% dl tinted windows
Bbk shortys
20"resonators
Roush ab.
Bama/mpt tunes
More coming visually for now.
Old 09-05-2015, 03:16 AM   #10
Cooolbreeez's Avatar
I avoid drive throughs and all tight spots where I might check a curb. My wife thinks I'm picky. It happens but I do everything I can to not let it happen. I always try to not park next to curbs as well.
Cooolbreeez is offline   Reply With Quote
Fixing curb rash Aruiz42 Mustang Wheels & Tires 5 12-18-2012 07:48 AM
To sand or not to sand? FortyBrandon Classic Mustangs 5 08-22-2012 11:52 PM
curb rash fix austinknoll Mustang Wheels & Tires 22 01-10-2012 08:29 PM
Curb Rash !!!!! stampde General Mustang Discussion 26 06-08-2011 07:38 PM
can you fix curb rash? Black00GT Pre-2005 V6 Mustang 4 02-24-2004 08:44 PM
10:07 AM
