First time clay barring - Mustang Evolution
Old 08-29-2015, 08:50 PM   #1
Any tips or tricks to make it easier the first time?
Vinnie02 is offline   Reply With Quote
Old 08-29-2015, 11:06 PM   #2
2011 Kona Blue's Avatar
Use lots of lube on her. 😆
Non 🍼and non 🌽fed. I $uck!
Old 08-30-2015, 06:50 AM   #3
Haha ok will do blue...thanks.
Old 09-04-2015, 11:37 AM   #4
Dispose of the bar if you drop it on the ground. Trying to salvage it will leave you with tons of scratches. Break the bar into a couple pieces so you don't have to throw out the whole thing if dropped.
Gray13 is offline   Reply With Quote
Old 09-04-2015, 11:41 AM   #5
Strange Mud's Avatar
+1 on either 1/2 or 1/3 pieces. It's pretty easy if it's too hard to move use more lube. w/o insulting wash 1st and you'll have to wax afterwards,
Have fun.
I do my rides 1x year, I only feel the difference, I can't see it but my vehicles look good.
Old 09-04-2015, 11:59 AM   #6
Take off your rings, if any.
Use plenty of lube. What brand will you plan on using? I use Mother's California Gold detailing spray and it works GREAT!
Keep the bar away from the soft rubber black trim.
Don't be afraid to rub moderately hard (again, with plenty of lube, the bar should NEVER drag on the surface). Even rubbing harder, the clay should just glide very easily, like ice on ice. If you are leaving ANY clay behind on the surface, you are not using enough lube.
Fold the bar over on itself after every section, so that you have a clean bar to start with.
Do your windshield too.
I use Griot's Garage clay bar, and I've found it to be one of the best. Very sticky and softer than some others I've used, and it picks up a lot of crud out of the paint.
Old 09-04-2015, 12:19 PM   #7
I bought a Meguires kit and it worked perfectly...she feels like a sheet of glass. Thanks again fellas.
First clay bar, first wax, first wash...glamour shots! Guard 5.0 2015 Mustang GT 15 06-29-2015 09:58 AM
Long time viewer, first time poster xxPIKExx New Member Introductions & Greetings 9 06-16-2013 10:53 AM
Any tricks to clay barring? Mustang32Bill Mustang Paint, Appearance & Detailing 13 10-21-2012 11:17 PM
Long time reader first time typer Gk1million New Member Introductions & Greetings 3 09-07-2012 11:29 AM
to clay or not to clay bigsmitty24 Mustang Paint, Appearance & Detailing 9 06-08-2012 03:24 AM
12:13 PM
