Question about cams and tuning for 4.6L 2v - Mustang Evolution
Go Back   Mustang Evolution > Vendors > AmericanMuscle
Old 11-05-2013, 01:42 PM   #1
So I've been thinking of maybe getting cams next summer. I know that BAMA usually doesn't tune for cams, but what if I were able to install them and then do some datalogging and send it to BAMA? Would they then be able to give me a tune for it? Still on the fence about everything, but if i do then they will be Ortiz-performance regrind cams, for mostly just sound and a little bit of performance in the process; all I will need is a tune to make sure i can drive the car with no issues.
Old 11-05-2013, 02:02 PM   #2
samuelsmith's Avatar
I don't know if this is 100% true. Some cams require you to port and polish or head upgrade to the engine.
edit: did not realize your rank. I am sure you know this man.
Orbits will tune, just ask David.
Old 11-05-2013, 02:05 PM   #3
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
We usually don't tune for custom ground tunes. There's a few select cams that we can tune for. I would recommend giving the Bama team a call and running your plan past them and see what they think!
Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764 and they'll get you squared away!
-Dan
Old 11-05-2013, 02:53 PM   #4
Get Houston performance 292 cams!!!
Lemme know what AM tells you lol
---------- Post added at 01:53 PM ---------- Previous post was at 01:52 PM ----------
Originally Posted by AMDanBailer View Post
We usually don't tune for custom ground tunes. There's a few select cams that we can tune for. I would recommend giving the Bama team a call and running your plan past them and see what they think! Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764 and they'll get you squared away! -Dan
What cams CAN you tune for??
KoolPwny is offline   Reply With Quote
Old 11-05-2013, 04:19 PM   #5
Originally Posted by samuelsmith View Post
I don't know if this is 100% true. Some cams require you to port and polish or head upgrade to the engine. edit: did not realize your rank. I am sure you know this man. Orbits will tune, just ask David.
I've already done my research on the cams and everything. I just already have BAMA tunes so if I could get around paying 550 to have it dyno tuned I would like that.
---------- Post added at 03:18 PM ---------- Previous post was at 03:17 PM ----------
Originally Posted by Bee20e View Post
Get Houston performance 292 cams!!! Lemme know what AM tells you lol ---------- Post added at 01:53 PM ---------- Previous post was at 01:52 PM ---------- What cams CAN you tune for??
I decided with the Ortiz regrinds because they re-use stock cam gears and are not aggressive enough to replace the springs, so it's really just a swap out. And they are only $450
---------- Post added at 03:19 PM ---------- Previous post was at 03:18 PM ----------
I'll do that, but probably in a while since If I do get the cams I won't be getting them until the end of next summer.
Old 11-06-2013, 09:08 AM   #6
AmericanMuscle.com
Sponsor
As long as it's a NSR set up, we can usually tune for it. If it's not a extremely aggressive cam, we can almost always tune for it as well! We'll just ask some questions about how it drives and do some datalogs and should be able to get you squared away.
-Dan
Old 11-06-2013, 09:58 AM   #7
As long as it's a NSR set up, we can usually tune for it. If it's not a extremely aggressive cam, we can almost always tune for it as well! We'll just ask some questions about how it drives and do some datalogs and should be able to get you squared away. -Dan
Woah that's bad ***!!
I was doubting AM for a while but damn they're good!!
Old 11-06-2013, 09:52 PM   #8
Well the cams I plan to get don't require aftermarket springs so do you think id be good?
Old 11-06-2013, 10:04 PM   #9
Make sure you call the dyno shop first. I live in MS and the closest tuner shop does not tune cams. Just my luck LOL I know to data log and e-mail tune. Is a dyno tune better? My uncle used his connections to get me a free e-tune.
Old 11-06-2013, 10:06 PM   #10
slow281
sixpac's Avatar
Region: Nebraska
Woah that's bad ***!! I was doubting AM for a while but damn they're good!!
Meh..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 11-06-2013, 10:22 PM   #11
Originally Posted by sixpac View Post
Meh..
lol
Old 11-06-2013, 10:27 PM   #12
Make sure you call the dyno shop first. I live in MS and the closest tuner shop does not tune cams. Just my luck LOL I know to data log and e-mail tune. Is a dyno tune better? My uncle used his connections to get me a free e-tune. t 03:18 PM ---------- Previous post was at 03:17 PM ----------
I don't want to sound rude, but did you read any of the posts above? I do not want to get it dyno tuned if I do not have to.
Old 11-06-2013, 10:57 PM   #13
This is why I did not personally respond to you. Other people read our post for 411 and do not join. There are too many Mustang forums and ours should have the best information. I am not trying to take over your post. Just had a general question and thought it belonged here.
Cams are awesome! Congratulations!
Old 11-07-2013, 12:13 PM   #14
AmericanMuscle.com
Sponsor
Yes! We should be able to get your car dialed in without any problems. Feel free to give me your contact information if you'd like and I can have our head tuning specialist reach out to you. He can collect the specs on the cam from you and just make sure there won't be any problems!
-Dan
Old 11-07-2013, 01:06 PM   #15
Yes! We should be able to get your car dialed in without any problems. Feel free to give me your contact information if you'd like and I can have our head tuning specialist reach out to you. He can collect the specs on the cam from you and just make sure there won't be any problems! -Dan
BUT!!!!
Would this qualify under the free tunes for life or would it be extra??
Old 11-07-2013, 01:08 PM   #16
I don't even know 100% sure if it's going to happen since it all depends on how well my summer job next summer goes and how much available cash I have. I'll make sure to give them a call around that time.
---------- Post added at 12:08 PM ---------- Previous post was at 12:08 PM ----------
BUT!!!! Would this qualify under the free tunes for life or would it be extra??
Should be free since I already have the tuner for this car.
Old 11-07-2013, 01:17 PM   #17
2300turboford's Avatar
Sorry to thread jack but can you tune comp cams 262?
Old 11-08-2013, 07:04 AM   #18
AmericanMuscle.com
Sponsor
BUT!!!!
Yes, this would fall under free tunes for life.
-Dan
Old 11-08-2013, 07:22 AM   #19
1lowGT's Avatar
I would dyno tube for cams no matter what.....
Old 11-08-2013, 07:40 AM   #20
ColeJohnson's Avatar
+1
2016 Comp Orange GT (current)
Old 11-08-2013, 02:34 PM   #21
It'll get dynod eventually. Just need it drivable.
Old 11-08-2013, 03:10 PM   #22
Terminator's Avatar
I would too but 550 for one session is outta of the question when you plan to add maybe fuel pump, injectors etc. down the road in a decent time frame
Terminator is offline   Reply With Quote
Old 11-08-2013, 03:37 PM   #23
1lowGT's Avatar
That's why dd suck. Can't do ****. You can't just tear it down and work on it over time.
Old 11-08-2013, 03:57 PM   #24
The Bullitt is probably going to be a show car after college. But right now I want cams and exhaust cutouts, just to intimidate everyone wherever I go.
---------- Post added at 02:57 PM ---------- Previous post was at 02:56 PM ----------
Exactly. I mean AED is good, but id rather not spend $550
Old 11-08-2013, 04:09 PM   #25
Terminator's Avatar
Yea my plan is to get a beater by feb. an begin working on a forged 4.6 or build mine for now bama's tune will suffice for the cams i have now
Old 11-08-2013, 04:33 PM   #26
1lowGT's Avatar
Bingo me too. I need a truck cuz dd winter drag radials mmmmm boy. Even with all seasons in screwed. That's my plan too rods pistons and cobra crank and boost it eventually.
11:12 PM
