Tuner/dump - Mustang Evolution
Go Back   Mustang Evolution > Vendors > AmericanMuscle
Old 02-04-2014, 03:08 PM   #1
Tuner/dump
When I install performance parts do I need to dyno it or can I just run a performance tuner on it?
Taylorbrt4 is offline   Reply With Quote
Old 02-05-2014, 10:29 AM   #2
Site Sponsor
Sponsor
AMWill's Avatar
Depending on the performance parts you're referring to, you may or may not need a custom tune. You'll always benefit from a custom tune, even with a bone stock Mustang. There's plenty of adjustments to be made to a stock car to improve throttle response and power throughout the RPM range.
A dyno tune is usually only necessary when your Mustang is heavily modified with a supercharger or turbo. For any bolt-on mods, a custom email order tune will work perfectly and just as efficient as a dyno tune, if not more efficient (depending on your tuner).
What kind of mods are running or planning to run?
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 02-05-2014, 12:55 PM   #3
Well I plan on running bbk cold air, bbk shorty headers with magnaflow cat back exhaust and a 65 mm throttle body.
Old 02-05-2014, 03:02 PM   #4
Site Sponsor
Sponsor
AMWill's Avatar
These are exactly the type of mods our Bama Performance Team writes tunes for every day. You'll absolutely see large improvements with a Bama custom tune, over stock! Is your '05 GT a manual or automatic transmission? If it's an auto, there's a lot of improvements to be made in the shift points alone.
Also, do you plan on changing the mid-pipe or cats? There's a good bit more power to gain there by switching to mid-pipe with high flow cats or using a catless mid-pipe. Especially since you're going to be using shorty headers.
Shane
Old 02-05-2014, 05:32 PM   #5
well my mustang is a manual. if you say that high flow cats work with mid pipe then thats what i will do. because this is the first performance car that i have owned. the people that i work with dont think a gt has that much potential. i want to show them other wise. how much experience do you have in all this stuff.
Old 02-06-2014, 08:49 AM   #6
Site Sponsor
Sponsor
AMWill's Avatar
Yes, high flow cats will help with sound and performance. However, if you're planning on buying shorty headers and a mid-pipe at the same time, you might as well go with LT headers and a shorty mid-pipe instead. You'll see more significant power gains with LT headers, than shorties.
I have a ton of experience with performance cars and Mustangs in particular. I've personally built numerous late model Mustangs, but I've also partaken in Bolt-On Build-Up projects here at AM. Check out our 2007 GT that we built up in multiple stages. It may give you ideas for your build!
Shane
texas
05:17 PM
