Poweraid spacer and BBK 73mm throttle body - Mustang Evolution
Go Back   Mustang Evolution > Vendors > AmericanMuscle
Old 08-06-2014, 02:45 AM   #1
grom80's Avatar
Hey guys...I did some research on this but could not really find much...
I have a 2013 V6 with (amongst many other mods...) a BBK 73mm throttle body purchased through American Muscle.
I was looking at getting a poweraid throttle spacer as well, but I am not finding much info on compatibility between the 2 accessories...American Muscle doesn't mention anything...
Anyone have a clue ?
Thanks
grom80 is offline   Reply With Quote
Old 08-06-2014, 02:58 AM   #2
natestang07's Avatar
I would venture to bet most will tell you to dave your money for something else.
05 Gt Premium Performance White, flowmaster outlaws
Old 08-06-2014, 08:45 AM   #3
Site Sponsor
Thanks
Grom
That's a good question and the Spacer is meant to be used in conjunction with the factory throttle body. I caught a ride in an employees V6 that had this equipped and while it produced a little more noise I honestly didn't feel that much of an improvement! This is just my .02! Let me know if you have any other questions and I'm here to help!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 08-06-2014, 05:14 PM   #4
grom80's Avatar
Thanks everyone for the advices...
Old 08-07-2014, 07:42 AM   #5
Site Sponsor
Anytime! Let me know if there's anything else I can help out with I'm always here to help out!
Alex
Old 08-08-2014, 09:51 PM   #6
grom80's Avatar
I talked to Airaid and they said if the butterfly valve is not obstructed, so do a visual before actually installing it...then it can work.
...but...how about performance ? Has anyone ever tried this ???? I may have to dyno it..only way I guess. Airaid say they have never tested it with an aftermarket enlarged throttle body.
Old 08-12-2014, 02:09 PM   #7
grom80's Avatar
Hey everyone...so, since it has been so hard to find any info on these 2 mods going together, I wanted to share my results on here for whomever encounters this in the future.
Wow !
I did a visual inspection of the butterfly valve in the BBK 73mm throttle body to make sure the valve does not hit any obstruction when mounted with the AIRIAD POWERAID SPACER (per airaid customer service suggestion...)...none whatsoever, actually they fit together quite nicely despite the smaller diameter of the spacer which is built to fit the OEM stock throttle body.
I installed it, reset the KAM in the computer using the SCT tuner...this way it clears all the computer memory and starts fresh.
I tried the car and was really impressed...now, I know there is a lot of anti-spacer "save your money for something else" attitude out there...but my issue with these engines is in the low end, where they suffer a little before they get up there and thrive...so my intention was to resolve that.
I swear to God it's a beauty...now perhaps it's a combination of all the mods I have (who the heck knows right ?), I listed them below...but with this spacer on I am feeling :
1. Far better throttle response than before, the car is really aggressive
2. Definite push on the low end that was NOT there before and it gets up high far faster than previously
3. The sound is wonderful...there's that whistle that almost emulates a turbo.
No check engine light, no DTCs from the computer...I checked...
so verdict ? Whetehr it's a combo of my mods I cannot say, but after being wary of the compatibility between the increased throttle body mod (BBK 73mm) and the POWERAID SPACER that is built for the stock throttle body diameter; I can safely say this worked like a friggin' charm for me.
BBK's theory is that whilst the diameter of the spacer is made for the stock size throttle, the bore that it has, to allow for air speed up and circulation, makes the outer diameter (pre-bore) of the opening the same as the increased 73mm throttle...if that makes any sense.
I am running a 2013 convert V6 engine with :
- BAMA race tune 91
- JLT Cold air intake
- BBK 73mm throttle body
- PYPES axle back exhaust (muffler deletes - BOMB)
- FORD RACING X PIPE
- JLT OIL SEPARATOR
- ROYAL PURPLE OIL
Old 08-13-2014, 01:06 PM   #8
Site Sponsor
Grom,
Thanks for posting this up! This is news to me about the compatibility and I'm going to have this link sent over to the appropriate teams here so we can look at having the listing changed. I'm happy to hear that you're enjoying it so much and that's it's improving the low end so drastically. This is a great review/writeup and I think you should make a separate post for it! Let me know if there's anything I can help out with in the meantime and I apologize for the misinformation on my end!
Alex
Wow !
I did a visual inspection of the butterfly valve in the BBK 73mm throttle body to make sure the valve does not hit any obstruction when mounted with the AIRIAD POWERAID SPACER (per airaid customer service suggestion...)...none whatsoever, actually they fit together quite nicely despite the smaller diameter of the spacer which i built to fit the OEM stock throttle body.
so verdict ? Whetehr it's a combo of my mods I cannot say, but after being wary of the compatibility between the increased throttle body mod (BBK 73mm) and the POWERAID SPACER, I can safely say this worked like a friggin' charm for me.
BBK's theory is that whilst the diameter of the spacer is made for the stock size throttle, the bore that it has to allo for air speed up and focus makes the outer diameter of the opening the same as the increased 73mm throttle...if that makes any sense.
- BAMA race tune 91
- JLT OIL SEPARATOR
- ROYAL PURPLE OIL
Old 08-13-2014, 01:19 PM   #9
grom80's Avatar
Hey Alex !
Not at all ! You are welcome...I'll post as new thread for everyone.
I will also dyno and get the figures soon...
Old 08-15-2014, 07:31 AM   #10
Site Sponsor
Hey Alex !
Awesome! Keep me in the loop if there's anything else I can help out with. I'm happy to hear that you're enjoying it so much!
Alex
BBK 73mm Throttle Body StewartL1189 General Mustang Discussion 14 09-10-2015 08:28 AM
Airaid Poweraid Throttle Body Spacer (11-14 GT) 2013fiveO 2011-2014 Mustang GT 29 06-12-2014 03:56 AM
JLT CAI with Steeda spacer, or BBK CAI and BBK throttle body? Aventador97 2005-2010 V6 Mustang 11 02-26-2014 04:12 PM
PowerAid Throttle Body 00vertstang Pre-2005 V6 Mustang 2 11-23-2004 04:58 PM
09:17 AM
