Venomous One :: 2003 Ford SVT Mustang Cobra - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Member Garages
Venomous One
PureVenom PureVenom is offline
Vehicle Name Venomous One
Year 2003
Make Ford
Model SVT Mustang Cobra
Color Redfire
Packages Convertible
2003 Ford SVT Mustang Cobra 2003 Ford SVT Mustang Cobra 2003 Ford SVT Mustang Cobra
History Ordered the car in August of 2002. Waited to take delivery the last week of May 2003. I planned to order the car in Sonic Blue...however not making any more by the time I ordered. Changed the order to mineral gray....however not making any more by the time I ordered. Finally gave up and said give me red. However, I was expected a bright red as they said they were no longer making performance red, they have a new color called redfire. I said fine, I'll take it.
Never knew what color redfire was until I saw the car back off the delivery truck. Perfect.
Exterior
2003 Ford SVT Mustang Cobra Exterior
  • Fore Precision Hood Vents
  • 8" Antenna
  • Roush Light Bar
  • Cobra front grill emblem
Interior
  • Hilton High Boost Overlay
  • MGW 6 speed pattern Shift Knob
  • Autometer dual gauge cluster bezel
  • AEM A/F Wideband Gauge
  • Kincaid Performance Inter Cooler Fluid Temp Gauge
In-Car Entertainment
None
Under the Hood
2003 Ford SVT Mustang Cobra Under the Hood 2003 Ford SVT Mustang Cobra Under the Hood
Show Stuff:
  • Redfire Powder coated valve covers
  • Fore precision custom engraved black Coil Covers
  • Custom Build tag
  • Hood Struts
  • Billetflow Redfire idler pulleys
Go Stuff
  • 2.2L Kenne Bell Super Charger
  • Customized Kenne Bell 3" upper pulley
  • Custom 4# Lower Pulley with Stock Cage
  • Billetflow single blade throttle body
  • JLT Red Carbon Fiber Ram Air Intake
  • 10" Air Filter
  • SCT BA2800 MAF
  • Seiman Deka 60# injectors
  • EGR Delete
  • Kincaid Killer Chiller
  • Nazman ported lower intake
  • LFP Dual Pass heat exchanger
  • Reiche performance 170* thermostat
  • Evenflow Head Cooling Mod
  • Black Powder Coated Canton IC Tank (installed soon)
  • Black Powder Coated True Forged Radiator Overflow Tank (installed soon)
  • Custom tuned by Myself
Suspension
  • Full Tilt Boogie delrin IRS bushings
  • Maximum Motorsports low profile IRS bolt and
  • 14mm IRS bolt
  • Maximum Motorsports Caster Camber plates
  • Maximum Motorsports full length subframe connectors
  • Maximum Motorsports front sway bar end links
  • Prothane steering rack bushings
  • Steeda X2 ball joints
Other
2003 Ford SVT Mustang Cobra Other
Wheels and Tires:
  • Anthrecite FR500 Rims: 17x9" front, 17x10.5" rear.
  • 275 45 17 Nitto NT05 tires on the front
  • 315 35 17 Mickey Thompson ET Street Radials on rear
Brakes:
  • Rotor Pro Cross Drilled and Slotted rotors
  • Hawk HPS brake pads
Drive Train:
  • UPR Firewall Clutch adjuster
  • Steeda Quick Release Clutch quadrant
  • Maximum Motorsports Clutch pedal height adjustment kit
  • Spec 3+ Clutch with light pedal effor
  • Spec rebuild-able steel flywheel
  • 26 Spline input shaft
Exhaust:
  • Bassani mid length headers
  • Bassani off road H pipe
  • Borla Stinger Cat Back
Items Waiting to be installed:
  • Black Chrome cobra letters for rear bumper
  • Russel brake speed bleeders
  • Maximum Motorsports front/read stainless brake lines
  • Maximum motorsports front coil over conversion
svt
07:29 PM
