1989 Ford Mustang Coupe - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Member Garages
Qwik Four Six's Avatar
Qwik Four Six Qwik Four Six is offline
Vehicle Name
Year 1989
Make Ford
Model Mustang Coupe
Color White
History She started life as a 2.3L Mustang. It was converted over to a 5.0, has the borg warner T% 5 speed, and had the 8.8 put in it also.
Exterior
1989 Ford Mustang Coupe Exterior 1989 Ford Mustang Coupe Exterior 1989 Ford Mustang Coupe Exterior
It is white with black striped molding and black pin striping. It has 15" weld drag lite on it also. 15x4 on the front and 15x8 on the back with Mickey Thompson ET slicks.
Interior
1989 Ford Mustang Coupe Interior 1989 Ford Mustang Coupe Interior 1989 Ford Mustang Coupe Interior
Stock interior with a thunder valley raceway tach and an aftermarket pistol grip shifter pioneer door speakers, infinity rear speakers, and ford racing floor mats.
Under the Hood
1989 Ford Mustang Coupe Under the Hood
302, e7 heads, full roller rocker 1.72 ratio, mild cam, aluminum valve covers to clear rockers, full underdrive pulley set, weiand x-cellerator intake, mac shorty headers, pertonix ignition, edelbrock carb( with 735 CFM venturis from carter carb), flowmasters that are dumped at the axle, T5 5 speed transmission, and urethane engine mounts.
Suspension
8.8 positive traction rear end with fomoco 3:73 gears, GT swaybar out back and 4-shock setup installed. Eibach sportline 1.5" lowering springs with V8 rates with cobra spec.
Other
1989 Ford Mustang Coupe Other 1989 Ford Mustang Coupe Other 1989 Ford Mustang Coupe Other
08:54 AM
