"syd" :: 2002 Ford Mustang Gt - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Member Garages
"syd"
bluegrassfever6 bluegrassfever6 is offline
Vehicle Name "syd"
Year 2002
Make Ford
Model Mustang Gt
Color Mineral Grey
2002 Ford Mustang Gt 2002 Ford Mustang Gt
Exterior
Chin spoiler, Set of Rear Anthracite deep dish bullitt 17x10.5 with NITTO EXTREME PERFORMANCE NT555 315/35x17 tires, Set of Front Anthracite bullitt 17x 9 with 275/40x17 EXTREME PERFORMANCE NT555 tires.
Under the Hood
Cold air intake, SCT custom tune, 3.73 FRPP gears, Spec Stage 2 clutch(530 ft-lbs) with Pilot and throw out bearings, Stack racing clutch quadrant, Fidanza Billett Aluminum Flywheel, FRPP clutch fork, C&L plenum, Aluminum Driveshaft, Steeda Tri-ax Short shifter, BBK long tube ceramic coated headers, BBK O/R X-pipe, Magnaflow catback exhaust, MIL eliminators, Urethane Motor mounts, Accufab 75 MM throttle body, Ford Racing 90 MM mass air flow sensor, Ford Racing differential cover, Mishimoto Silicone hoses
Suspension
Drilled and Slotted front and rear rotors with ceramic pads, Maximum Motorsport full length Powder coated subframe connectors, Steeda lowering Springs, Set of Tokico HP series front struts, Set of Tokico HP series rear shocks, Swarr Bar, Steeda tubular front sway bar, Steeda Auminum 4-bolt caster/camber plates, Steeda rear shock tower brace
05:36 PM
