The Sickness :: 2011 Ford Mustang GT - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Member Garages
The Sickness
Mr. Anderson's Avatar
Mr. Anderson Mr. Anderson is offline
Vehicle Name The Sickness
Year 2011
Make Ford
Model Mustang GT
Color black
Packages optioned Premium car w/ brembo's, HID's, and 3.73's
Exterior
2011 Ford Mustang GT Exterior 2011 Ford Mustang GT Exterior
Forgestar F-19x9's & R-19 x 11's
HO Fibertrend 3" cowl hood w/ aerocatch latches
Carbon 3D GT500 spoiler
saleen grill
20% tint
Interior
2011 Ford Mustang GT Interior 2011 Ford Mustang GT Interior
Corbeau A4 Leather seats
In-Car Entertainment
2011 Ford Mustang GT In-Car Entertainment
Metco dash kit
Pioneer AVIC Nav/DVD head unit
Under the Hood
2011 Ford Mustang GT Under the Hood 2011 Ford Mustang GT Under the Hood 2011 Ford Mustang GT Under the Hood
Kenne Bell 2.8LC W 168mm TB running 12 lb of boost
Evolution Performance 75lb flow matched injectors
Kenne Bell boost-a-pump
BBK ceramic coated LT headers
3" OR-H pipe, lethal performance 2.75" OTA pipes & Corsa Extreme axleback
& John Lund, 91 octane street tune
Snow performance stage 2 meth kit
McCleod RXT twin disk clutch w/steel flywheel and JHR clutchline
MGW shifter
shaftmaster 1 piece DS & CHE DS loop
JPC linelock
FRPP rearend girdle
Suspension
2011 Ford Mustang GT Suspension 2011 Ford Mustang GT Suspension
Koni Yellow shocks and struts and steeda strut mounts
FRPP "P" springs
slotted and dimpled rotors
UPR UCA
J&M LCA and BMR LCA relocation brackets
BMR 3rd member poly bushing
UPR DA panhard bar
BMR rear swaybar relocation kit
CHE axlebrace
Other
2011 Ford Mustang GT Other 2011 Ford Mustang GT Other 2011 Ford Mustang GT Other
with the track shoes on and at the track
weld RT-S:
F- 17 x 4.5 & R- 15 x 10
Old 08-28-2013, 08:36 AM   #2
badass car
Old 03-22-2015, 10:24 PM   #3
What times do you run in this beast?? It's bad *** man
Phase 3 upgrade including CAI, Fuel pump voltage regulator, (648rwhp), 582 torque, Kooks LT headers with off road H pipe, Vossen CV3's, ID1000's, Steeda Heat Exchanger, BMR LCA's,relocation brackets, adjustable Panhard bar, Rear sway bar, Steeda Aluminum driveshaft, X-brace, Differential cover, torque box brace/frame rails, Shelby trans cooler, Mcleod RST clutch/lightweight steel flywheel w/SS clutch line, RP fluids, whiteline transmission bushing,MGW race spec short shifter,Ford racing twin 65mm throttle body, Pro Dyno tuned
jamyzd30 is offline   Reply With Quote
02:25 PM
