Living Legend :: 1990 Ford Mustang GT - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Member Garages
Living Legend
Living_Legend's Avatar
Living_Legend Living_Legend is offline
Vehicle Name Living Legend
Year 1990
Make Ford
Model Mustang GT
Color Shadow Gray
Exterior
2003 Dark shadow gray Cobra paint
Cervinis Cobra R 2.5 inch cowl hood
Cervinis Cobra grill with pony insert
Cervinis Cobra rear wing
LX Tail lights
Smoked head lights and fog lights (HID bulbs)
Tinted windows 35% on windshield and 15% on all other windows
18" by 9" Saleen reproduction front wheels with Dunlop Direzza Dz101 tires
18" by 10" Saleen reproduction rear wheels with Dunlop Direzza Dz101 tires
Interior
SVE S2 Racing Seats w/ Rear Seat Delete
Under the Hood
1990 Ford Mustang GT Under the Hood
Bama SCT 4-Bank Eliminator Chip Tune
Solid motor mounts
Aluminum heads 202 intake 160 exhaust valves
1.6 Crane cams roller rockers
Double sprung valve springs
Trick flow hardened push rods
B303 cam Ford motorsport
Ford Racing Valve Cover Gaskets
Gt 40 tubular intake
Gasket matched ported lower intake
SR Black Out Cold Air Intake
BBK egr spacer
70mm throttle body
BBK 76mm Mass Air Meter
Accel High Performance EV1 Fuel Injectors - 24lb
BBK Adjustable Fuel Pressure Regulator
Walbro 255 Lhp High Pressure Fuel Pump
BBK under drive pulleys
Smog Pump Removed w/ 84.5” Belt
Flowtech long tube headers 1" 5/8 primary
Flowmaster H-Pipe w/ Delta 40 mufflers
Rebuilt T5 transmission with hardened syncros
B&M ripper short throw shifter
NGK Iridium IX Spark Plugs
Ford Racing Plug Wire Set
Performance Distributor Cap Rotor Kit
180 Degree Thermostat w/ Chrome Water Neck
High torque mini starter upgrade
3G alternator upgrade 130amp
Mallory ignition box
Mallory pro master coil
Aluminum radiator
Black Magic electric fan
Battery relocation with Red Top Optima battery
Ford motorsport 3:73 rear end gear
Suspension
5 Lug swap and rear disc conversion
Cobra front brakes 14" with drilled and slotted rotors
Cobra rear brakes 12" with drilled and slotted rotors
Summit racing brake proportioning valve
Eibach 2" lowering springs
06:17 PM
