dragging with auto? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 08-29-2011, 09:16 AM   #1
5.slow's Avatar
Region: Delaware
dragging with auto?
I know someone who took his 2000 gt to the track to get a baseline time and started off the line in first gear and then maxxed out the rpm's before shifting up with his auto trans. Is that the proper way of racing with an auto? Just wondering cuz I want to get a baseline time for my car with aod and stall torque converter.
5.slow is offline   Reply With Quote
Old 08-29-2011, 09:35 AM   #2
Re: dragging with auto?
you NEVER EVER want to put it in neutral and then put it in drive to take off *VERY BAD*
the best you can do is to hold the brake and rev up until right before the tires spin. When the light turns let off the brake and get on the gas.
Old 08-29-2011, 09:39 AM   #3
5.slow's Avatar
Region: Delaware
I don't think he started in neutral. He started in first and manually went up to 2nd and then manually to drive.
Old 08-29-2011, 09:46 AM   #4
oh, I see. On newer transmissions its not an advantage to manually shift, let the computer do it for you. A tune can modify shift points and pressure much better and can get better results than you trying to do it yourself.
Old 08-29-2011, 10:17 AM   #5
You can try that to see how it works, but you may be better off letting it shift for itself.
They used to do something called the 1-2 shuffle in the Fox Body auto trans Mustangs. Don't remember exactly why.
You might want to research that and see what you can learn about it.
SpectorV, he has an AOD not the AODE unless he has changed it, so tuning the shift points with a tuner won't work.
Your choices for launching are foot brake or use a line lock.
You will have to experiment a bit to determine your optimum launch RPM.
You want it high enough that it doesn't bog and low enough that it doesn't spin.
Old 08-29-2011, 10:51 AM   #6
5.slow's Avatar
Region: Delaware
Yeah I have the stock aod. As far as the 2000, he already tuned it with the sct tuner which should have modified the shift points already?
Old 08-30-2011, 01:25 PM   #7
5.slow's Avatar
Region: Delaware
Is it a waste of time to heat up street tires?
Old 09-04-2011, 07:34 PM   #8
No, but then you won't ever see the benefits from them as easily as you will a set of slicks or drag radials either.
Old 09-09-2011, 04:56 PM   #9
94 Mustang GT's Avatar
The sct tuner for the 5.0 should be a chip. Can't just scan them like the 4.6.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 09-10-2011, 01:29 PM   #10
deadsp0t's Avatar
The 1-2 shuffle..
Is when you manually shift into 2nd then pull back into 1st. When you do this the car does NOT shift back into 1st, but allows you to keep it in 2nd and manually shift into 3rd. This is not a great way to treat your tranny, but it will allow to control the 1st - 2nd, then control the 2nd - 3rd shift.. Use this at your own risk.
That's unimpressive
Old 09-10-2011, 01:38 PM   #11
Originally Posted by deadsp0t View Post
The 1-2 shuffle..
Yupp...can be detrimental to your trans...but I've done it a dozen or so times with no consequences.
Old 09-10-2011, 05:17 PM   #12
deadsp0t's Avatar
My understanding is that it is a fail safe to keep the driver from tearing something up V. Performance option lol
That's unimpressive
Old 09-10-2011, 06:14 PM   #13
Virgin92's Avatar
I used to drag race my old 1989 this way and after awhile u will Start to lose overdrive.. Happened to me and my brothers 92!! It's the only way to get the car down the track without a modified tranny
Virgin92 is offline   Reply With Quote
Old 09-11-2011, 09:44 AM   #14
The 1-2 shuffle..
That's it. I couldn't remember the particulars.
Thanks!
Old 09-11-2011, 10:20 AM   #15
deadsp0t's Avatar
Np man! I had an 86 5.0 T bird and an 91 3.8 T bird, I shifted both those cars this way. The 86 was total lost before I got torn up, but I did tear up the one in the 6 that way... SMH
That's unimpressive
Auto to manual swap Jamesgt08 1996-2004 Mustang GT 6 06-25-2011 01:45 PM
05:22 AM
