anyone else autox??? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 04-29-2012, 01:22 AM   #1
DaBluedude's Avatar
So I've been autocrossing my mach 1 the past couple weekends and I've got another event tomorrow. I'm just doing it for fun. Anyone else autox? I'm wondering what you guys run for tire pressures. Some of the guys run upwards of 45psi. Sofar I've only used the stock 32. I love the quarter but there is something fun about a good autox
2003 Mach 1
Old 04-29-2012, 01:40 AM   #2
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I auto cross a few times a year and plan on going again in May. I go up to 41lbs on my front tires to help turn in. How much camber are you running?
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 04-29-2012, 01:52 AM   #3
DaBluedude's Avatar
Just stock. Only had the car 5 months and it doesn't need an alignment. Ill be keeping it flat because Its a DD... I feel like the car needs a strut tower brace and a set of rear control arms bad.
2003 Mach 1
Old 04-29-2012, 02:02 AM   #4
Enjoy your Mach. I would probably pass on the strut tower brace and go with subframe connectors instead. Strut tower braces to far less than subframe connectors when it comes to chassis stiffening. But strut braces sure do look nice. Are you seeing your times get better with experience?
Old 04-29-2012, 02:04 AM   #5
DaBluedude's Avatar
A little yeah. I've probably got 100 hours of road course and I'm punching above my class in auto x. The mach has subframe connectors stock. But there are stiffer out there. It just doesn't tuck into tye corners
2003 Mach 1
Old 04-29-2012, 02:05 AM   #6
Just wanted to add that I run 1.5 degrees of negative camber on my daily driven Bullitt and my tires are wearing perfectly even. Since I increased the camber I'm much more competitive at auto crosses.
Old 04-29-2012, 02:14 AM   #7
DaBluedude's Avatar
Ill keep it in mind. I like the sport a lot. And killing a evo10 by 7 seconds was hilarious.
2003 Mach 1
Old 04-30-2012, 10:09 PM   #8
I've done a few open track events. I set my tires at 5 psi above street so around 37 psi for me. Worked pretty well. Bet that evo guy was pissed lol
1990mustang5.0 is offline   Reply With Quote
10:31 AM
