helmet - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 04-30-2012, 02:27 PM   #1
helmet
My buddy gave me a couple helmets. He used them on his motorcycle and I was wondering if they were the same as racing helmets. All I know is they are dot approved.
Old 04-30-2012, 02:32 PM   #2
fultonboy09's Avatar
I have heard that motorcycle helmets go above the requirements of dot regulations for racing helmets if they are Snell 2000 or better. Someone correct me if I'm wrong. (I'll take the one you won't use if I am right though. lol)
fultonboy09 is offline   Reply With Quote
Old 04-30-2012, 02:54 PM   #3
What does the Snell 2000 symbol look like? I do know that they are pretty old. I did see a 95 something inside of a symbol. I will check them out a little better I just didn't know what to look for.
Old 04-30-2012, 02:56 PM   #4
That's all I know man! Sorry but I don't ride!
Old 04-30-2012, 02:57 PM   #5
I appreciate it though. I'll see what I can find out.
Old 04-30-2012, 03:06 PM   #6
deadsp0t's Avatar
The snell approval should either be on the back with the dot approval or it could be under the padding on the inside. There is now a snell 2010 approval out and all snell 2000's have been removed from retail stores, in short I wouldn't be inclined to wear a snell 2000 on a bike unless I knew the manufacture date was 2005 or newer. Pretty sure places that would require a helmet would require an up to date approval as well. Dot helmets are generally ok for 5 years and snell up to 10, that's considering it's never been in an accident or dropped from let's say waist high.
That's unimpressive
Old 04-30-2012, 03:08 PM   #7
deadsp0t's Avatar
Oh, a snell approval is a real deal testing system as they pull random samples from store shelves for testing not ones sent by manufacture for testing. A pretty high percentage have to pass to obtain approval.
That's unimpressive
Old 04-30-2012, 03:10 PM   #8
Thanx dead. These helmets are pretty old, maybe close to 10 years. I'm not actually sure if its gonna be required.
Old 04-30-2012, 03:14 PM   #9
deadsp0t's Avatar
What brands are they? Certain brands, all their helmets are snell.
As long as they are clean, look to never have been dropped, in an accident or painted they are likely ok to use for drag racing.
That's unimpressive
Old 04-30-2012, 03:16 PM   #10
One says cirus and other says b12
Old 04-30-2012, 03:19 PM   #11
deadsp0t's Avatar
Never herd of those.. Look under the padding inside, should be a manufacture date sticker in there. Find it and use your judgment based on the date and condition whether you use. Inside you'll get a look at the condition as well. My advice is be very picky about used helmets bro.
That's unimpressive
Old 04-30-2012, 03:20 PM   #12
Ok. When I get home I will look at it closer. Thanx for the advice.
Old 04-30-2012, 03:22 PM   #13
deadsp0t's Avatar
Np, I've done lots of research on this subject as there are several helmets I want badly but are upwards of $1000... Motorcycle info is something I have plenty of resources for info on. Post up some pics, I'd love to take a look.
That's unimpressive
Old 04-30-2012, 03:25 PM   #14
I did post. Were you able to see it?
Old 04-30-2012, 03:31 PM   #15
deadsp0t's Avatar
Oops I had over looked it lol
Snell on the back of mine.
Snell M2005 approval on inside
Manufacture date/stamp and inspection
That's unimpressive
Old 04-30-2012, 03:35 PM   #16
Sweet. Thanx ill check it out soon. You have been very informative. Nice helmet btw.
---------- Post added at 04:35 PM ---------- Previous post was at 04:34 PM ----------
I don't plan on doing a whole lot of track. I basically just want to see what she does and wanted to be prepared just in case.
Old 04-30-2012, 03:36 PM   #17
deadsp0t's Avatar
Thanks bro! And you are most certainly welcome! Safety first!
That's unimpressive
Old 04-30-2012, 06:17 PM   #18
this is the green helmet
http://www.powersportsnetwork.com/en...tCategoryCode=
Old 04-30-2012, 10:15 PM   #19
deadsp0t's Avatar
HJC makes a decent lid for the money
That's unimpressive
Old 05-04-2012, 11:03 AM   #20
JimC's Avatar
Re: helmet
Most tracks will require the Snell rating and not the DOT, and anything older than a Snell 2005 is now out of date. Depending upon your track you might get away with a 2000, it all depends upon how safety conscious they are. I know that one track I go to would let me run with my Snell 2000, but a different one I go to will not let me run unless I use the Snell 2005 minimum.
Road course tracks will require the Snell SA 2005 or newer. At a drag strip you can use the Snell M 2005 until you start running in the single digits.
JimC is offline   Reply With Quote
Old 05-04-2012, 11:06 AM   #21
Ok good to know. Thanx
Old 06-22-2012, 08:58 PM   #22
ccorlet's Avatar
Re: helmet
See if your track has a website. They might list everything you need to know there like mine does... Firebird Raceway
2012 Mustang GT
ccorlet is offline   Reply With Quote
04:40 AM
