Manually shifting automatic - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 05-15-2012, 08:17 PM   #1
I'll manually shifting an automatic make you faster in a quarter mile?
Blackedout is offline   Reply With Quote
Old 05-15-2012, 08:20 PM   #2
Lorraine's driver
ab_mach1's Avatar
Only if it has manual valve body. Most modern auto trannys have a 1 to 2 shift no matter what.
Instagram: @ab_mach1
ab_mach1 is online now   Reply With Quote
Old 05-15-2012, 08:25 PM   #3
Will this work?
Old 05-15-2012, 08:27 PM   #4
Forum Car Trader
90GTNovi2000's Avatar
+1 that.. what he's saying is you can leave it in low and the computer and trans will shift at the highest shift point at WOT. So unless it's a manual valve body as stated its not very much difference.. But take it to your local track and run it both ways an figure it out.
90GTNovi2000 is offline   Reply With Quote
Old 05-15-2012, 08:27 PM   #5
Lorraine's driver
ab_mach1's Avatar
Will this work?
The only advantage would shifting when you want to shift to the next gear. Doesn't the tuners allow you to change shift points on the auto's?
Old 05-15-2012, 08:31 PM   #6
http://www.americanmuscle.com/perfor...body-9604.html
Old 05-15-2012, 08:37 PM   #7
Lorraine's driver
ab_mach1's Avatar
I believe that's a shift kit. Manual valve body will allow you to be in any gear at anytime, save reverse. If you are at a stoplight sitting there, you can put in 3 if you are so inclined. I'm not sure if you can install that without removing the tranny. I had manual valve body on a TH350 I had put in my 84 Z28 years ago.
10:42 AM
