05-24-2012, 08:38 PM
#1 | | Registered User
| street tires/drag radials/slicks
question... there are some slicks and weld prostars for sale for 300 bucks, and they only have 10 passes on them on CL
my question is however, are going to slicks this soon going to do more damage then good?
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
06-07-2012, 06:13 PM
#2 | | Registered User
Good question , I have a 00 gt with bolt on s and 410 and on 245/45/17 it smokes the tires 1 an 2 with no launch so I just order nito 555 Dr on 10.5 rims I'm afraid in going to break somethin I'm going to the track this Saturday will let you know what happens
06-08-2012, 06:57 AM
#3 | | Registered User
| Re: street tires/drag radials/slicks Quote:
Originally Posted by Topless04GT question... there are some slicks and weld prostars for sale for 300 bucks, and they only have 10 passes on them on CL
my question is however, are going to slicks this soon going to do more damage then good? | What are your mods? You'd be fine in my opinion.
SOLD - 06 GT 371WHP/332WTQ
Coming Soon - GT500
06-08-2012, 10:05 AM
#4 | | Legacy Member
If you don't have axles already you'll be needing them. Also make sure you're not running a radial tire up front with a bias ply rear
Mine: -03 SB Cobra vert- 2552 of 5082 Born 02/25/03
Our's: 90 7up vert - new project-07 DSG Focus -DD 335 |
06-08-2012, 06:30 PM
#5 | | Senior Member
| Quote: |
Originally Posted by lowflyn If you don't have axles already you'll be needing them. Also make sure you're not running a radial tire up front with a bias ply rear | i didn know this. your saying i cant run my falken street tires with my hoosier slicks? and sorry not trying to thread jack. |
06-08-2012, 08:05 PM
#6 | | Legacy Member
I wouldn't recommend it, could lead to high speed wobbles.
The bias ply rears tend to float and without a similar tire on the front it will float on the track. Just don't steer with the sway and you should be ok... Just not fun.
06-09-2012, 02:16 PM
#7 | | Senior Member
| Quote: |
Originally Posted by lowflyn I wouldn't recommend it, could lead to high speed wobbles.
The bias ply rears tend to float and without a similar tire on the front it will float on the track. Just don't steer with the sway and you should be ok... Just not fun. | Thanx for the info
06-09-2012, 07:45 PM
#8 | | Registered User
| Quote: |
Originally Posted by dreamstang
Thanx for the info | Just got back from the track , I launched hard and got some good times , no floating or high speed wobbles
06-09-2012, 07:51 PM
#9 | | Evolution's Finest
Do you need to warm up drag radials? I know this does nothing really for summer/all season tires.
__________________ |
06-09-2012, 08:04 PM
#10 | | Filibuster
| Quote: |
Originally Posted by Azure Do you need to warm up drag radials? I know this does nothing really for summer/all season tires. | Yup..my m/t et streets are still quite slick before you heat them up..but then its a whole new monster when there warm.
06-09-2012, 08:15 PM
#11 | | Evolution's Finest
| Quote: |
Originally Posted by XXSTEVEO66
Yup..my m/t et streets are still quite slick before you heat them up..but then its a whole new monster when there warm. | Little baby warm ups, or gettin busy warm ups?
06-09-2012, 08:26 PM
#12 | | Senior Member
| Quote: |
Originally Posted by tommy d
Just got back from the track , I launched hard and got some good times , no floating or high speed wobbles | And you used radicals up front with slicks in the back? After lowflyn stated not to earlier I did some research. And a lot of people seem to do it. And the wobble can be fixed by raising the tire pressure, but you sacrifice traction.
06-09-2012, 08:28 PM
#13 | | Legacy Member
If you're comfortable with it then go for it. Just not recommended
06-09-2012, 08:29 PM
#14 | | Evolution's Finest
| Quote: |
Originally Posted by lowflyn If you're comfortable with it then go for it. Just not recommended | What is a better option for up front when your running DR's?
06-09-2012, 08:40 PM
#15 | | Registered User
| Quote: |
What is a better option for up front when your running DR's? | Skinnies
06-09-2012, 08:46 PM
#16 | | Evolution's Finest
| Quote: |
Originally Posted by fultonboy09
Skinnies | K, just googled that and gained knowledge. Thx! What's a typical width for Mustangs? Can this actually help your time too? Or just stability?
06-09-2012, 08:50 PM
#17 | | Legacy Member
For drag radials you can normal fronts. It's when you move to a slick it becomes important. A skinny will help your times however as it reduces rolling resistance and weight
06-09-2012, 08:54 PM
#18 | | Evolution's Finest
| Quote: |
Originally Posted by lowflyn For drag radials you can normal fronts. It's when you move to a slick it becomes important. A skinny will help your times however as it reduces rolling resistance and weight | I follow now. Thanks!
06-09-2012, 09:06 PM
#19 | | Filibuster
| Quote: |
Little baby warm ups, or gettin busy warm ups? | M/T's seem to like smokey burnouts...but all tires are different.plus track temps and conditions would change that also..
06-09-2012, 09:10 PM
#20 | | Evolution's Finest
| Quote: |
M/T's seem to like smokey burnouts...but all tires are different.plus track temps and conditions would change that also.. | Cool, thanks!
06-09-2012, 09:33 PM
#21 | | Legacy Member
| Quote: |
M/T's seem to like smokey burnouts...but all tires are different.plus track temps and conditions would change that also.. | I normally do a good 2nd gear burnout to get enough heat in them
06-09-2012, 09:36 PM
#22 | | Evolution's Finest
| Quote: |
I normally do a good 2nd gear burnout to get enough heat in them | So with DR's, you definitely want to get in the water box? I've been going around w/street tires.
06-09-2012, 09:44 PM
#23 | | Registered User
with street tires you DEF want to go around the box. you will make some avid draggers very unhappy if you take water up to the starting line. no matter how big a burnout you do on streets, if you went to the water box, you will still bring water up to the line. with DR's you should be fine.
06-10-2012, 08:30 AM
#24 | | Legacy Member
| Quote: |
Originally Posted by Topless04GT with street tires you DEF want to go around the box. you will make some avid draggers very unhappy if you take water up to the starting line. no matter how big a burnout you do on streets, if you went to the water box, you will still bring water up to the line. with DR's you should be fine. | I would pull around the box and back into it. With a normal radial on the front you will just drag water to the line
06-10-2012, 07:07 PM
#25 | | Registered User
Originally Posted by Topless04GT with street tires you DEF want to go around the box. you will make some avid draggers very unhappy if you take water up to the starting line. no matter how big a burnout you do on streets, if you went to the water box, you will still bring water up to the line. with DR's you should be fine. | This isn't always possible. At ATCO, the archway is where they have the water. You HAVE to drive through it to get to the line. It is pretty dumb actually.
Coming Soon - GT500
06-10-2012, 11:30 PM
#26 | | Registered User
that sucks... but im sure drivers have that understood then i would imagine.
and whenever I go if I have any form of street tires, they never touch the water.
06-15-2012, 08:37 AM
#27 | | Registered User
I have a 2006 saleen with low 400rwhp and 4.10 gears! I'm planning on getting 15" wheels for track setup, what kinda tires would everybody recommend I get?
06-17-2012, 02:46 PM
#28 | | Registered User
| Quote: |
Originally Posted by syrupsaleen I have a 2006 saleen with low 400rwhp and 4.10 gears! I'm planning on getting 15" wheels for track setup, what kinda tires would everybody recommend I get? | Mickey Thompson's et streets
