Made it down the track - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 08-18-2012, 10:07 AM   #1
Tominkc's Avatar
Send a message via Yahoo to Tominkc
Ell I ran my car for the first time last night!! Didn't do to bad! Made 4 runs. Speed got faster buy my ET was up and down! Traction was the pits last night! All the 5.0's were spending bad! The last run was against a 13 5.0 with a pro charger!! Pulled him off the line! I start to spin. So. Bad when I shifted in to 3 that the wheels broke loose as soon as I let out the clutch.and the engine over reved so bad treat I tried to shift to fourth and missed a gear! Dam, I might have had him, but he flew by me! I'll be putting up my time slips here in a little bit.
Tominkc is offline   Reply With Quote
Old 08-18-2012, 10:10 AM   #2
Bladezx's Avatar
I heard ford has scouts at tracks now looking for plates etc and using it to void warranty. Is this really true?
Bladezx is offline   Reply With Quote
Old 08-18-2012, 10:21 AM   #3
Re: Made it down the track
Bwhahaha.....don't give the worry-warts more to ponder.
Mine's been out once; like you said mph is all over the place, typical when you're learning shift points etc. I've done 12.9 on it and a best mph 113.9.
Old 08-18-2012, 10:21 AM   #4
Tominkc's Avatar
I haven't heard anything about it. The track I went to was about 60 miles from home! It was called steer and tune!! Anyone could go!
Old 08-18-2012, 10:24 AM   #5
Bladezx's Avatar
I'm just letting people know. Thats what a salesman I know really well told me. That's what they are doing in Canada don't know if that's in the states too. He also said the new vehicles hve recorders in them that tell what km it's been redlined or how fast etc
Old 08-18-2012, 10:27 AM   #6
Tominkc's Avatar
The 13 50had wheel hope really bad, the 2012 5.0's didn't have much week hop at all! Fix Ford do something different on the rear suspentiin on the 13's ! I. Know I have to do something to mine to help get better hook ups! Spun so bad last night any suggestions !
Old 08-18-2012, 10:30 AM   #7
Loc: Austin,TX
LCAs and some sticky tires.
Old 08-18-2012, 10:35 AM   #8
Tominkc's Avatar
My time from first to last run: 105 mph ET 13.8 60' - 2.4. 2nd run 109.ph ET 14.8 60'-2.7. 3rd run 111.4 mph. ET 13.4. 60'-2.3. 4th run. This one was bad could not hook up at all 93.7mph ET 14.2 60' 2.2! That's what I did last night! Traction was really bad!
Old 08-18-2012, 11:43 AM   #9
My '12 BBP 3.73 wheelhopped so bad I had it going into 4th gear. I had to pedal the car in all 3 lower gears abit to contain it. It's endemic to all S197 Mustangs (and frankly all mustangs since 64-1/2). Easy fix: Put the upper control arm of your choice in there.
Old 08-18-2012, 11:46 AM   #10
Tominkc's Avatar
Ok! I believe that's the first step, along with some slicks!! How good are the radial slicks?
Old 08-18-2012, 11:54 AM   #11
I've used drag radials alot. There is a learning curve there. Unlike a bias slick where, because of construction and compound, you need very little burnout to heat and if you overdo it, you make them greasy; a drag radial doesn't like to warm up. A good smoky burnout is required to get some heat into them. I found once the tread wore mostly off, they were at their best. Nice thing about DRs also is no funky sway at the top end. They do stick but, people ***** because they don't understand how to use DRs, mostly.
make sure you get the right size. If you're on stock motor or stock + tune and 3.73s, you'll want a 28" tire to prevent shifting to 5th at top end. under that gear, you can get away with the cheaper, more available 26" tire on that motor combo.
Old 08-18-2012, 12:35 PM   #12
Tominkc's Avatar
I have a SCT 93 race tune, shorty headers, Magna flow Catbacks, comp series, with H pipe! And stock 19 tires!! 3:73 gear. I never hit 5 gear last night!!
---------- Post added at 01:35 PM ---------- Previous post was at 01:33 PM ----------
The track was just to slick!! No one cold hook up! Temp last night was 76* hi humidity!!
Old 08-18-2012, 02:09 PM   #13
Yep, I was at my track last night and it was 90+ degrees so everyone slowed up b/c of that + th high humidity made it unpredictable on the start line. I'm running a 4" contact patch sportbike so, me and my bike friends feel it first.
Old 08-18-2012, 02:19 PM   #14
Tominkc's Avatar
I can imagine !! It would scare the **** out of me, and I raced motocross!! There were some fast bikes last night one did a 8.3 at159 mph
Old 08-18-2012, 02:57 PM   #15
yep, thing's are prettty sick today. My 1k is an 07 and its done 155 in the 1/4 on the stock motor, tune and mufflers.
Last night a dude had a new 14r kawi and that thing rocked 9.6 all night long. Stock with a slip on.
06:08 PM
