What will i run at the track?? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 09-02-2012, 12:31 PM   #1
Jake's Avatar
Hey guys, im probably taking my car to the track this weekend or next but i was wondering what you guys think i will run
07 GT Auto
Pypes OR H pipe
Pypes Muffler Deletes
C&L Racer CAI
Bama Tuned
Those are my mods, if were to get 4.10s how much improvment could i see?
I have read a few things from you guys on here. Avoid water with my street tires, spin em for a few seconds. Brake and rev to 2k or so, let off brake and ease into it. Is this correct? Also TC off or on? I assume on? O/D off or on? Thanks for any input guys! I cant wait!
Jake is offline   Reply With Quote
Old 09-02-2012, 01:54 PM   #2
06rick's Avatar
i bet you run around 13.7,and after a few runs maybe 13.3.run with o/d off and keep us informed how you do.
06rick is offline   Reply With Quote
Old 09-02-2012, 02:02 PM   #3
Jake's Avatar
Awesome, with 4.10's could i see 12's?
Old 09-02-2012, 02:11 PM   #4
Re: What will i run at the track??
I would think 14,,maybe 13.8,,alot depends on the track
mymustang is offline   Reply With Quote
Old 09-02-2012, 02:19 PM   #5
Jake's Avatar
Dang i hope atleast in the 13's
Old 09-02-2012, 02:47 PM   #6
tc x 4's Avatar
TC off for shur, 14.5 first time out I'm guessing. If you leave with a 13.5 you should be very proud, let us know how it went.
Old 09-02-2012, 02:51 PM   #7
Is it your first time to the track?
Old 09-02-2012, 02:58 PM   #8
Stang.racr's Avatar
Mid 13s and high 12s possible with 4.10s-4.30s with a drag radial
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 09-02-2012, 03:00 PM   #9
Jake's Avatar
Yes its my first time.
---------- Post added at 04:00 PM ---------- Previous post was at 03:59 PM ----------
Okay so traction control off?! Seems like i would do a bunch of spinning!
Old 09-02-2012, 03:04 PM   #10
Lorraine's driver
ab_mach1's Avatar
I'd go T/C off and O/D off. The more runs you do in a day, you'll see slower times because of heat soak. I'd try leaving from idle at first, to see how easily you spin your tires. If no spin, maybe you can tinker with braking and increasing RPMs. You'll get much better traction at the track than on the street. Your gonna have a ton of fun!
Instagram: @ab_mach1
Old 09-02-2012, 03:06 PM   #11
tc x 4's Avatar
Spinning is better than the motor falling flat on It's face and running a 15+ run.
Old 09-02-2012, 03:10 PM   #12
Jake's Avatar
Okay, ill go with it! The drags here start at midnight! Ill start from idle first go around! I just really wanna see 13's!
Old 09-02-2012, 04:51 PM   #13
Franco09GT's Avatar
High 13's maybe, My opinion you get drag tires first before gears. Traction is everything at a drag strip.
Franco09GT is offline   Reply With Quote
Old 09-02-2012, 05:03 PM   #14
Jake's Avatar
Also newbie question, what dies running with OD off benefit me??
Old 09-02-2012, 05:07 PM   #15
Lorraine's driver
ab_mach1's Avatar
I don't think anything other than keep the tranny from going into OD once you get through the 1/4 and start slowing down. IMO its easier on your tranny.
Old 09-02-2012, 05:16 PM   #16
Stang.racr's Avatar
I don't think it matters if you turn it off or leave it on, you won't touch overdrive regardless as long as your car runs all the way to red line in each gear.
Old 09-02-2012, 05:17 PM   #17
Jake's Avatar
Okay, awesome guys! So do i roll into the throttle or punch it since im starting at idle?
Old 09-02-2012, 05:44 PM   #18
I would rev a little while holding the brake,,the throttle is drive by wire so it has a little hesitation before responding,,after awhile youll get used to it and get off the line faster..I acually did better with traction control,,i spun a lot without it..I have the sct 93 tune,,my best time was 14.2..14.8 with the traction control off..ALSO they usually have water at the beggining,,i guess to help with the guys with slicks,,avoid that if you have reguilar tires,,if they get wet youll have to burn them to get them dry..The track has alot to do with it,,that night it sucked..I still had a blast though
Old 09-02-2012, 05:50 PM   #19
Jake's Avatar
Okay so rev to around 2k??
Old 09-02-2012, 05:52 PM   #20
Stang.racr's Avatar
Uep
Old 09-02-2012, 06:11 PM   #21
Jake's Avatar
Since the drags here dont start till midnight will that help my time bring cooler out?
Old 09-02-2012, 06:46 PM   #22
Lorraine's driver
ab_mach1's Avatar
Yup, cooler is always better. Only time cooler is not better is if it's below your tire temp design. Like if you have summer tires, your traction will start to suck as you go below 40-50 degF.
Awesome your track opens at midnight!!!
Old 09-02-2012, 06:54 PM   #23
Do us mustangs pround..lol..have fun
Old 09-02-2012, 07:08 PM   #24
Jake's Avatar
It should be around 60 to 70 degrees! And yea its pretty cool, 10 dollars to watch 20 to race as much as you want.
---------- Post added at 08:08 PM ---------- Previous post was at 08:08 PM ----------
I will! I just really wanna see 13's!
Old 09-03-2012, 09:53 AM   #25
Well how did it go,,its the next day just wondering
Old 09-03-2012, 12:50 PM   #26
Jake's Avatar
Next weekend!
Old 09-03-2012, 01:02 PM   #27
Next weekend!
opps..lol
Old 09-03-2012, 01:09 PM   #28
Jake's Avatar
opps..lol
Your good bro!!!
Old 09-04-2012, 12:28 PM   #29
Site Sponsor
Sponsor
AMWill's Avatar
07 GT Auto
Pypes OR H pipe
C&L Racer CAI
Bama Tuned
Attachment 66710
Jake,
Looks like you have the right idea down for launching at the line. I would guess your first few runs being in the high 13s or lower 14s until you get the feel down. It can be really tricky sometimes with street tires, since they seem to break loose very easily. Once you're used to the track and launching your car, I think you could get a 13.3-13.5 out of your setup.
4.10 gears will most likely hurt your 60' time with street tires. Gears like that just want to accelerate as harshly as possible, which is good if you're running a drag radials/slicks. Otherwise, you'll find yourself breaking loose in 3rd gear with street tires.
Hope this helps some. Good luck at the track!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 09-04-2012, 01:03 PM   #30
Jake's Avatar
Originally Posted by AMShaneLesky
Jake,
Shane
Awesome thanks Shane! That what i really want is just 13's! Ill let you guys know how i do!
Old 09-05-2012, 07:40 AM   #31
Send a message via AIM to Borii
Originally Posted by AMShaneLesky View Post
Jake,
Shane
breaking loose in 3rd on street tires only happens on **** tires. I have 4.10s and street tires at 340 whp with 320 tq, manual. I don't break loose in any gear except 1st. Street or strip. Only weather in the 50s or less allow them to break loose. 4.10s severely help your 60, not hurt.It only suffers at first when you are learning. 1.81 60 with 4.10s on street tires.
OP, low 13s should be your goal in warm temps.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 09-05-2012, 02:43 PM   #32
Jake's Avatar
Awrsome thanks! I have Falken Azenis 245/40/20's they seem to be good tires!
Old 09-05-2012, 02:46 PM   #33
Jake's Avatar
Old 09-23-2012, 10:20 AM   #34
Jake's Avatar
Well i finally ran last night. I wasnt ready at all and it was pretty much a last second thing. I didnt get a time sheet, i guess at the track around here they only do time sheets on friday nights after test and tune. But i had a couple buddies there and they said i ran a low 13. Kinda dissapointed wanted to run a 12, but im happy, i could have lost some weight, had the spare in the back and a bunch of random crap also in the trunk lol, and i didnt have my tuner with me or i would have switched to the race tune, i ran street tune. So next weekend im going and losing some weight and loading the race tune. I should have a link to youtube for my run soon i will post. And on the crappy side i think my alternator took a crap on me this morning. Was turning into my driveway, i put my blinker on and pulled in, i then noticed that my blinker wouldnt shut off?? And then i realized all my dash lights were dim, my radio wasnt even on, and i couldnt do anything, my car was about to die, so i shut it off before i put it in the garage to see what was going on, (stupid idea) it wouldnt restart, so i put it in nuetral and pushed it into the garage. So now is the PA performance alternator from AM good??
Old 09-23-2012, 02:39 PM   #35
Jake's Avatar
The dodge is my buddies. Huge injectors, twin turbos, fast truck. Ran low 13's all night.
06:51 AM
