1/4 mile times - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 10-20-2012, 07:40 PM   #1
bradtaylornator's Avatar
1/4 mile times
Anyone got any info on stock 1/4 mile times for 2012 5.0 automatic?
bradtaylornator is offline   Reply With Quote
Old 10-20-2012, 09:01 PM   #2
2011 Kona Blue's Avatar
Fast,
Old 10-20-2012, 09:26 PM   #3
nhcowboy's Avatar
Well, 2011 auto with a bama 93r tune and pilot super sports ran 12.538 in Baytown tx a few months ago. Really hot and humid.
I believe you were supposed to have more HP than me stock... So with a decent tune and DR/slicks... You should hit low 12s/high 11s.
Pure stock 2012 auto on stock tires probably mid/low 13's. without a tune, the auto lacked punch off the line.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 10-21-2012, 08:34 AM   #4
Yea it does seem a little weak down low. I think its got 3:15s in it. Im really wanting to put 3:55 or 3:73 on
Old 10-21-2012, 10:13 AM   #5
CorDog009's Avatar
Yea, 3.15's stock. Gears will help out a good bit, the list goes from there. The tune helped mine out a lot.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 10-21-2012, 11:09 AM   #6
Yea i got the outlaw axelback. I know that doesn't help any for performance but it does sound damn good next step is intake and tune. Im just worried about voiding my warranty
Old 10-21-2012, 03:02 PM   #7
OneSick07's Avatar
I ran last night at speedworld in Phoenix my 13 ran a best of 13.37 at 108 completely stock just a set of bridgstone re760 275/35/r18s
OneSick07 is offline   Reply With Quote
Old 10-21-2012, 03:43 PM   #8
Is it auto?
Old 10-21-2012, 03:48 PM   #9
OneSick07's Avatar
No it's a 6 sp there was an 2012 auto that ran 13.6 tho
Old 10-21-2012, 03:57 PM   #10
I'm surprised to hear the 2012 5.0 automatic ran 13.6 in the 1/4. My understanding the 12 v6's with a tune are running 13.7 in the 1/4 mile with stock tires and 2.73 gears. I'm sure the 12 5.0's can high 12's low 13's with a great launch.
Old 10-21-2012, 04:23 PM   #11
I would really like to find out but Tulsas last drags until spring time were last night and i missed it!
Old 10-21-2012, 04:28 PM   #12
The Blue Dragon
GrabberBlue5.0's Avatar
Sounds like bad driver, bad weather, or bad track to mw
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 10-21-2012, 05:01 PM   #13
I was thinking that to (bad driver), but you figure with an auto its just floor it and the transmission does the rest. Juice it a go.
Old 10-21-2012, 05:11 PM   #14
nhcowboy's Avatar
They just need to find the RPM to brake hold their torque converter that gives quick launch without spinning.
12.538 ET @112.33
Old 10-21-2012, 05:17 PM   #15
The Blue Dragon
Yea easier than a manual, but still not brainless lol
Old 10-21-2012, 05:59 PM   #16
DaBluedude's Avatar
2012 gt / Cs auto bone stock ran a 13.4 @108 at our track. 5600ft nice day. Tiny tail wind. It ran the same mph all day.
2003 Mach 1
Old 10-21-2012, 07:35 PM   #17
Wow. I'm surprised. Perhaps those 13.4 runs are 5.0's with 3:14 stock gears. Still, I thought the 5.0's were running like 12.6 to 12.9 stock.
Old 10-21-2012, 07:40 PM   #18
nhcowboy's Avatar
3:15 gears are standard and the factory tune severely hampers acceleration and throttle response. That is why a tune should be the first upgrade for any 11-13 gt auto owner. That alone gets them mid to low 12s (some even in 11s).
12.538 ET @112.33
Old 10-21-2012, 07:55 PM   #19
Will a tune voodoo warranty?
---------- Post added at 08:55 PM ---------- Previous post was at 08:55 PM ----------
Void! f##### auto correct!!!
Old 10-21-2012, 08:08 PM   #20
nhcowboy's Avatar
It will put a hex on your warranty!
This is could be a thread in itself.
Officially, yes. And they can for all intensive purposes tell if you loaded a tune, then flashed back to stock.
But it only should affect warranty on the things the tune will impact (engine/trans/ECU). A defective control arm would't be impacted for example.
Some dealerships are cool and would work with you (none I've ever dealt with though) if something breaks.
12.538 ET @112.33
Old 10-21-2012, 08:12 PM   #21
moved to "at the track"
Old 10-21-2012, 08:47 PM   #22
The Blue Dragon
5600 ft of elevation plays a HUGE roll in that
Old 10-21-2012, 10:32 PM   #23
I know the 3;55 and 3:70 gears are options on the 5.0 but with that much power I would think 3:55 would be standard. Not 3:15 gears.
Old 10-21-2012, 10:36 PM   #24
nhcowboy's Avatar
Standard on the auto (which the OP has). No option on the auto for any other gears from the factory.
The auto's ratios are a bit different than the manual for 11-13. Hence the 3:15
12.538 ET @112.33
Old 10-22-2012, 05:13 AM   #25
So since the auto is different than the manual would that cause any issues going from 3:15 to a 3:55 or 3:73 without a tune. Im trying to stay under my warranty as long as i can, but its really hard to keep it stock with so much easy potential
Old 10-22-2012, 05:16 AM   #26
Lorraine's driver
ab_mach1's Avatar
+1
Instagram: @ab_mach1
Old 10-22-2012, 06:23 AM   #27
nhcowboy's Avatar
1) you'd want 4:10 (those that have it don't regret it) assuming you don't go forced induction. 4:10s would be a bit aggressive at that point.
2) a tune would only be needed to effectively correct the speedo as it wouldn't be accurate.
3) a tune would still drastically improve throttle response, shift strategies, and TQ/HP. Would compliment the gear swap.
12.538 ET @112.33
Old 10-22-2012, 06:55 AM   #28
Thanks for the input. Im pretty knew to tuning and everything. Im used to atvs where you just throw some bigger jets in, and not have to worry about all the computer programming. Its also nice to have someone explain to you without being a jacka$$ just because they know more than me.
Old 10-22-2012, 08:23 AM   #29
nhcowboy's Avatar
No problem!
Good luck!
12.538 ET @112.33
Old 10-22-2012, 09:40 AM   #30
The Blue Dragon
Hey hope you're not talking to me, never meant to come off that way if so... Sorry brother!
Trust me I've answered many questions on here and I am only ever rude to those that come on here acting like an *** clown lol
Old 10-22-2012, 11:28 AM   #31
No man not at all. I should have been more specific. I meant a totally different site all together
Old 10-22-2012, 11:53 AM   #32
The Blue Dragon
O lol, I think I know exactly where you're talking about lol
Old 10-22-2012, 12:12 PM   #33
Haha which one?
Old 10-22-2012, 01:57 PM   #34
The Blue Dragon
I'm not gonna start a forum war lol, if you're that curious just pm me
Old 10-22-2012, 04:00 PM   #35
Haha just seeing if you'd say the name
04:51 AM
