running lean?? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 11-27-2012, 04:08 PM   #1
Pony up's Avatar
running lean??
So i was told by a mechanic that my car is running lean and that it could be the JLT CAI or the tune..... any one else run into this??
Pony up is offline   Reply With Quote
Old 11-27-2012, 04:12 PM   #2
2008crna's Avatar
Check your tune. If you use a CAI without tune it will cause a higher air mixture to fuel ratio (hence the term running "lean"). I suggest returning your car to stock with your tuner and then reflashing to the tune you want. This makes sure you start from a clean flash instead of reflashing a bad tune. You must do this soon. Running lean is bad for your engine.
2008crna is offline   Reply With Quote
Old 11-28-2012, 10:47 PM   #3
rebeltx's Avatar
+1
And if you have the option, send in any data logs to whoever does your tune and have them update it. This is popular with the 2011+ guys that have Bama tunes
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
08:39 AM
