What would it take to run low-mid 14's? - Mustang Evolution
Go Back   Mustang Evolution > General | Audio | Detailing | Wheels | Track | Regional > At the Track
Old 12-16-2012, 06:47 PM   #1
Seabiscuit's Avatar
Seabiscuit is unknown around these parts
I have an 05 v6 with a bbk cai, Bama 93 hybrid tune, and a dual exhaust. Best run so far was a 15.115 at 94.8 with a 2.3 60'
Any help/input would be much appreciated...sorry if I posted in the wrong section, I wasn't sure where was best for this.
Seabiscuit is offline   Reply With Quote
Old 12-16-2012, 06:52 PM   #2
Eturner's Avatar
Eturner is unknown around these parts
Do you have an auto or stick?... Gears, UD Pullies, and full exhaust will get you down to!..
Old 12-16-2012, 06:56 PM   #3
Seabiscuit's Avatar
It's a stick, I knew I forgot to mention something! I was hoping to have 3.73's by spring time but I'd also need a t-lo or new rear...stupid one wheel peel. Would long tubes be the way to go even though I have to keep my cats?
Old 12-16-2012, 08:03 PM   #4
Speed_Mister's Avatar
Speed_Mister is unknown around these parts
From what I've done and tested on my car:
Headers -.4
X pipe o/r -.2
Tb/p -.2
Under drive pulley's -.1
Every 100 pound = .1
Torque converter = .7
Remove front sway bar, a/c, relocate battery to back trunk, remove front and rear bumper supports they don't do anything but support up to 25 mph so they font do crap anyways plus no body can tell, if you don't know how to power shift it helps alot don't let go of the gas and as you pull out of gear to the next quickly, you very quickly stomp on the clutch you need to be very fast at it to so you don't grind synchro's like I did learning how to or you get to learn to rebuild a transmission learning how to get it down perfect. What size tires you have? And do you spin any at the front line?
2003 Mustang GT 5 speed Manual: BBK Cold Air Intake, Trick Flow 75mm tb/p, Steeda Under Drive Pulley's, SCT Bama 93 Race tune, BBK O/R X-Pipe, Flow Masters Mufflers, King Cobra Clutch, 31 Spline Differential, 31 Spline Moser Axles, 28X10.5-11.5 Hoosiers Quick Time Pro Drag Slicks, 60ft 1.75, 330ft 5.28, 1/8 8.25 @ 83, 1000ft 10.65 @ 94.
Old 12-16-2012, 08:08 PM   #5
Seabiscuit's Avatar
I had a set of bald 235/50/17 falkens last time I was there. Now they're 275/40/17 nitto 555s. I'm hoping to get into 14's with just the change in tires but I'm rather new at the track. I think I've made 12 passes.
Old 12-16-2012, 08:16 PM   #6
EHH! That'll get you close to your goals like a 14.6 maybe a 14.5
Old 12-16-2012, 08:20 PM   #7
Seabiscuit's Avatar
That'd definitely make me happy! I really just want to close up the gap between my car and my friends '13 genesis.
Old 12-16-2012, 08:25 PM   #8
Hahah! And if it doesn't you could take your jack and spare out when you run that's like 30 easy pounds.
Old 12-16-2012, 08:25 PM   #9
08Mustang's Avatar
08Mustang is unknown around these parts
Nobody makes underdrive pulleys for the 4.0...but ASP makes an underdrive crank pulley/ harmonic balancer which is rated at 15HP and 10 ft/lb...they "claim"
08Mustang is offline   Reply With Quote
Old 12-16-2012, 08:29 PM   #10
Seabiscuit's Avatar
I'll have to look into that, as long as it won't cause any harm lol
Old 12-17-2012, 08:24 AM   #11
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
AMDanBailer is unknown around these parts
Seabiscuit,
Those times don't sound to bad, it just sounds like you need some traction! If you get that 60ft time down into the 1.'s you'll definitely break into the 14's.
I agree with a Set of Gears, Tire and maybe a few more bolt ons and you'll be in great shape for mid to low 14's!
I hope this helps. Let me know if you have any questions or need some assistance! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266.
-Dan
Old 12-17-2012, 06:12 PM   #12
08Mustang's Avatar
Originally Posted by AMDanBailer
Seabiscuit,
-Dan
Dan! Get AM to carry that ASP underdrive crank pulley! I'd love to see it on AM!
Old 12-18-2012, 09:53 AM   #13
AmericanMuscle.com
Sponsor
Let me see what I can do! We definitely need to get some underdrive pulleys in there for the S197 V6 guys.
I'll get this sent over to my Purchasing team and see what they think! As soon as I have more information, I'll be sure to hit you up.
I hope this helps! Let me know if you have any questions or need some assistance with anything.
-Dan
Old 12-20-2012, 11:32 AM   #14
08Mustang's Avatar
-Dan
Thanks Dan, as always!
Old 01-18-2013, 08:46 AM   #15
Borii is unknown around these parts
Send a message via AIM to Borii
You already have a mid 14 in that car. Your launch is what is holding you back. A simple 2.0 60 foot would be enough for a 14.55X or 14.6XX
SOLD - 06 GT 371WHP/332WTQ
Coming Soon - GT500
Borii is offline   Reply With Quote
Old 01-22-2013, 01:50 AM   #16
davidcseifert's Avatar
davidcseifert is unknown around these parts
just juice it
SSM S3 heads, P&P lower, comp 218/226 cam, 4.2 bottom end, 3k stall, flow 40's, O/R x-pipe, Pacesetter lt's, SCT xcal2 (93 Ortizperformance tune), Windstar upper, 65mm tb, CAI, FRPP T-lok, 3.73's, SFC's, cut factory springs, KYB shocks/struts, MM LCA's
Sponsored by Ortiz Performance, great tunes at a good price!
Old 01-28-2013, 05:13 PM   #17
Seabiscuit's Avatar
Thanks for all the responses guys, hopefully when I go back this year I run better
12:44 AM
