First trip down the 1/8 - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 12-21-2012, 06:38 PM   #1
1996v6stang's Avatar
Well guys my pony is gonna make its first trip down the 1/8 tonight, wish me luck.
1996v6stang is offline   Reply With Quote
Old 12-21-2012, 07:24 PM   #2
sally2002's Avatar
Good luck and post times
sally2002 is offline   Reply With Quote
Old 12-21-2012, 07:45 PM   #3
v8pony's Avatar
Goodluck brotha! Lookin forward to seein them times!
2002 5spd GT
Feb 2013 Mustang of the Month
Old 12-21-2012, 08:54 PM   #4
1slosix's Avatar
anyone wanna guess how it'll go? i'll say 10's just because it's the first trip
good luck op
carving corners like a boss
Old 12-21-2012, 10:41 PM   #5
deadsp0t's Avatar
good luck op
10.00-10.40's
9.90's on a perfect day
That's unimpressive
Old 12-21-2012, 11:33 PM   #6
1slosix's Avatar
i remember my last 1/8th trip...best of 10.3 with my sixer. i like 1/4 mile runs, but the fun of 1/8th tracks around here at least mean on test and tune nights you get in alot of run quicker.
Old 12-22-2012, 12:10 AM   #7
Well it was quite the bust. Broken wheel stud=no passes for my. My buddy on the other hand ran a 9.5 his 2nd or 3rd pass. 04gt auto with cai and tb, no tune. This was also his first time at the strip.
Old 12-22-2012, 12:36 AM   #8
1slosix's Avatar
Yeah being an auto is nice in some situations...one being drag racing. Tell your buddy he needs a new Plenum so that tb will do something more then look new and shiny.
Old 12-22-2012, 12:37 AM   #9
1slosix's Avatar
Btw did you know the stud was broke beforehand?
Old 12-22-2012, 04:17 AM   #10
deadsp0t's Avatar
Tune is not the big deal its made out to be in regards to pre 2005 Mustangs.. Does it help? Of course... It's not like the newer cars that will barely run after a CAI w/o a tune.. I'd love to see his times w/ a tune added and nothing else.
Doesn't sound like a TB helps the cause either.
That's unimpressive
Old 12-22-2012, 10:36 AM   #11
Yeah i new it was broke but i work like 10-11 hours a day and when i went in for wheel balancing at firestone the quoted me like 85 bucks. I was like ill just wait till i have time. But as for my buddys car i was just surprised it ran that for one of his first trips. I feel like it woulda been a lot better with a tune though to adjust the shift points and a little extra power.
Old 12-23-2012, 12:17 AM   #12
davidcseifert's Avatar
Region: Arkansas
It's always fun at my "local" track nothing like the smell of alcohol on the weekends haha first time I went out on this setup managed low 9's traction problems and factory gears blow
blower/new cam soon
Old 12-23-2012, 01:19 AM   #13
1slosix's Avatar
85 to replace a stud...or am i reading that wrong
Old 12-24-2012, 09:23 PM   #14
Whats ur setup?
---------- Post added at 12:23 AM ---------- Previous post was at 12:20 AM ----------
Thats right! I was told you have to pull the axle out to replace a wheel stud on the rear.
Old 12-24-2012, 09:56 PM   #15
1slosix's Avatar
lol no...i had to replace all the studs in my '04 GT...just use an impact and pull them through the hub...go on youtube and watch a vid on how to do it....super easy
for example my friend snapped 2 studs a day before our track visit...i had him swing by my house after going to Advance to buy a couple studs ($1.99 each)..took me 30 mins beginning to end with my crappy impact
Old 12-24-2012, 09:58 PM   #16
Hmm okay thanks ill check it out!
Old 12-24-2012, 09:58 PM   #17
1slosix's Avatar
np...pm me if you have any questions
Old 12-24-2012, 09:59 PM   #18
Will do!
Old 12-24-2012, 10:03 PM   #19
1slosix's Avatar
btw Davids setup is a stock v6 :shiftyeyes....ok not exactly a stock v6 but still it's not heavily modded.......ok it's heavily modded
Old 12-25-2012, 12:22 AM   #20
Haha nice whats the details on his stang?
Old 12-25-2012, 12:43 AM   #21
1slosix's Avatar
lol read his sig
Old 12-25-2012, 01:59 AM   #22
lol read his sig
I ca nt cause i use mobile app. I dont get to see sigs.
Old 12-25-2012, 02:24 AM   #23
Region: Arkansas
current list: SSM stage 3 heads with 1.94/1.56 valves, P&P factory lower intake with IMRC's removed, windstar upper intake, comp 218/226 cam, comp cam's 1.7 pro magnum roller rockers with hardened pushrods, 4.2 bottom end, ortizperformance 93 tune, pacesetter long tube headers, O/R x-pipe, flow 40's dumped at axle, Revmax 3K stall converter, shift kit, trans cooler, ford racing lsd, ford 3.73's, sub-frame connectors, cut factory springs and kyb shocks/struts
and to help put some of that to the ground 275/40-17 nitto 555's with maximum motorsports lower control arms...
(I have this saved to my phone, it's a lot to type lol)
---------- Post added at 03:24 AM ---------- Previous post was at 03:23 AM ----------
You can turn sigs on under your settings btw
blower/new cam soon
Old 12-25-2012, 02:34 AM   #24
Woww. What are u pushing? What u run in the 1/4?
Old 12-25-2012, 02:41 AM   #25
Region: Arkansas
Last I dynoed it still had the crappy "high flo" cats on it and made 242sae whp later found out the drivers side was clogged lmao
I ran a 14.2 balling the tires off and with the clogged cat i mentioned above, since then I've made a lot more passes but short tracks only, 8.72 @ 78.8 in 1/8th and 11.25 @ 89.X 1000' which should be around 13.4ish in 1/4
blower/new cam soon
Old 12-25-2012, 04:43 AM   #26
Nice man! Sooo you could spank my stang haha
Old 12-25-2012, 11:47 AM   #27
Region: Arkansas
Thank ya haha
blower/new cam soon
Old 12-25-2012, 12:22 PM   #28
Thank ya haha
U have any clips of ur car? Id love to hear it
Old 12-25-2012, 12:30 PM   #29
Region: Arkansas
Dyno
Track run
Boredom lol
blower/new cam soon
Old 12-25-2012, 12:41 PM   #30
Wow thats sick man. Any other plans for it?
Old 12-25-2012, 12:44 PM   #31
Region: Arkansas
New heads and bigger cam coming soon, possibly a different intake setup, and I have a zex nitrous kit sitting in my house right now
blower/new cam soon
Old 12-25-2012, 12:45 PM   #32
Horseplay's Avatar
david ur sixxer is one badass biatch
Low2v
Old 12-25-2012, 01:02 PM   #33
Wowww! Thats one v6 i sure as hell wouldnt **** with haha.
Old 02-16-2013, 01:20 PM   #34
Finally got to run her last night, i got beat a lot lmfao but my best run was against another stang, same year as mine but i won i ran a 9.83 on sumitomos. With a ****ty reaction time, and it didnt tell me my 60ft. But i was averaging some ****ty ****in 2.7 avg 60 ft times. All i can do is spin the hell out of these sumis.
08:37 AM
