Aluminum or carbon drive shaft for the drag strip - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 02-21-2013, 12:29 PM   #1
rebeltx's Avatar
I'm looking into a new drive shaft for my mustang but I'm not sure what is better. I know the carbon is the lighter of the two but it is also not as torsionally stiff. In my mind that means it wouldn't be the best for the drag strip since you want your power going to the wheels and not into twisting the DS.... Am I correct in saying that the aluminum one is better for my application because it is more stiff even though the carbon weight about 2Lb's less?
I asked the manufacturer and this is what they said the carbon is the better choice but you have to think they would say that because it is also more expensive.... Here is what they had to say...
"the carbon is more torsional than aluminum but its what helps, diring loading it twists about 30 degrees so it will not shock the tires
loose. also when it unloads it does it at a slower rate then a Steel or aluminum so again its not shocking the tires loose. most cars
will see a .01 to .003 60ft increase alone from this shaft. "
Is this true? What's the better choice for my application?
USA-
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 02-21-2013, 12:30 PM   #2
BaSohol's Avatar
Go with aluminum it's cheaper and u won't notice a 2 pound diff
2007 Ford Mustang GT 5spd
Old 02-21-2013, 01:59 PM   #3
1 pounds rotational mass equals about 6 pounds or dead weight. So the CF is lighter, but I believe for drag racing your best choice would be the aluminum.
Old 02-22-2013, 08:55 AM   #4
Send a message via AIM to Borii
Either one will be fine until a certain HP number
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 02-23-2013, 04:32 AM   #5
rebeltx's Avatar
I'm not going to go much over the 500 or 600 HP mark so most of the aftermarket shafts will work for my application. I'm just trying to figure what would be better for my application. Not to mention I can't find an aluminum shaft in stock but I know of a place with the carbon ones.
Old 02-23-2013, 04:54 AM   #6
Coreyw428's Avatar
Region: Arkansas
The bad thing with the carbon is if they get damaged in any way they are very likely to fail... They had an article about them in a magazine I read
Coreyw428 is offline   Reply With Quote
Old 02-23-2013, 08:28 AM   #7
my shaftmasters was 16 lbs and 600 bucks or so
Sold - 2001 Audi S4
Old 02-23-2013, 10:37 AM   #8
BaSohol's Avatar
How'd you like it? Before and after??
Old 02-23-2013, 04:48 PM   #9
Made the low end power come back a little for day to day since the cams and tunes had taken away a little low end. Eliminated ALL sounds the car would make when shifting or otherwise.
Sold - 2001 Audi S4
Old 02-23-2013, 05:05 PM   #10
2011 Kona Blue's Avatar
AM just got there one piece aluminum driveshafts back not more than 10 days ago. I know this because I ordered one and was delivered three days ago. Good lord. What did they sell all of them in a week and half
Old 02-24-2013, 07:33 PM   #11
rebeltx's Avatar
yea... there sold out. Im thinking of going with the DSS one from CFM
01:56 AM
