Pretty disappointed! - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 05-20-2013, 08:11 AM   #1
IIAMSTARK's Avatar
So I went to my local track this weekend, and I am not happy with my time. I am running an 11.7 in the 1000ft. My friend in his 03 GT is running 10.5's with slicks. . Why is his time more than a second faster?! Is it because he has slicks and 4.10's when I'm on street tires with 3.55's?
IIAMSTARK is offline   Reply With Quote
Old 05-20-2013, 08:22 AM   #2
Mustang936's Avatar
Most likely due to his shorter gearing and extra traction due to slicks. I also think that the new edges have a small advantage when it comes to weight. But you have more HP, i would say it could be due to a good launch and slicks and some nice shifting.
Mustang936 is offline   Reply With Quote
Old 05-20-2013, 08:36 AM   #3
IIAMSTARK's Avatar
I was thinking the same thing. He also has a lot of stuff taken out of his car, sway bars, bumper supports, etc. I have some drag radials, and I am swapping my 4.10's in this week. Hopefully that will help my time.
Old 05-20-2013, 11:59 AM   #4
Mustang936's Avatar
You will definitely see some better times with gears and radials. If the 03 is a full bolt on he might still be able to get close to you what other mods are you and him running?
Old 05-20-2013, 05:57 PM   #5
IIAMSTARK's Avatar
He is full bolt on except headers, he also has a tune. I have Comp Cam Mutha Thumpa cams, BBK 62mm throttle body, JLT CAI, my heads are Ported and polished, I have a tune, and I have full exhaust, w/ longtubes.
Old 05-20-2013, 08:40 PM   #6
Aggiesrok's Avatar
You need gears to get that low end back from the cams.
Old 05-21-2013, 05:36 AM   #7
Wolverine0587's Avatar
And get some actual good cams. Those Mutha Thumprs are almost only good for sound.
Wolverine0587 is offline   Reply With Quote
Old 05-21-2013, 09:24 AM   #8
Send a message via AIM to Destination S19
So I went to my local track this weekend, and I am not happy with my time. I am running an 11.7 in the 1000ft. My friend in his 03 GT is running 10.5's with slicks. Why is his time more than a second faster?! Is it because he has slicks and 4.10's when I'm on street tires with 3.55's?
Damn, I pulled 11.2 in the 1000ft on 275/40/18 NT555s with 3:31 gears and only a tune/cai. The slicks definitely help him but they shouldn't be that significant unless he has the power to use them.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 05-23-2013, 07:01 AM   #9
IIAMSTARK's Avatar
I got 4.10's put in on Tuesday. Hopefully this weekend I can hit low 11's. I will probably run my drag radials too.
---------- Post added at 08:01 AM ---------- Previous post was at 07:59 AM ----------
I also bogged every single time, even launching at 3500 it still bogged a little. I think it's just because of my cams and gearing.
Old 05-23-2013, 08:05 AM   #10
08mustanggt's Avatar
How do you find the difference between the 3.55 and 4.10? Looking at installing mine tomorrow.
08mustanggt is offline   Reply With Quote
Old 05-23-2013, 08:53 AM   #11
IIAMSTARK's Avatar
I like them. I don't get much traction through second gear, but it pulls a lot better. Gas mileage didn't change a whole bunch. Two or three MPG, but if I really cared about gas mileage I would have got a Prius.
Old 05-23-2013, 10:06 AM   #12
Aggiesrok's Avatar
[QUOTE=IIAMSTARK;1661729]I got 4.10's put in on Tuesday. Hopefully this weekend I can hit low 11's. I will probably run my drag radials too.
Awesome, keep us posted on your results. Good luck this weekend.
Old 06-28-2013, 09:04 AM   #13
I am wondering why you even asked this question. It seems like you already knew the answer ._.
KickinClaire is offline   Reply With Quote
Old 06-30-2013, 10:08 AM   #14
IIAMSTARK's Avatar
I didn't know if I was missing something.
11:28 AM
