Trying to run low 12s on street tires - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 06-10-2013, 03:22 PM   #1
1st stang's Avatar
I have a 2013 5.0 with x pipe and flowmaster outlaws, steeda lowering kit it's a auto. And I can't find a good tire for the 19" brembo wheels. Fastest time so far is a 12.9
1st stang is offline   Reply With Quote
Old 06-10-2013, 03:33 PM   #2
that isnt a bad time...i have a 12, and yet to do the 1/4 mile run, I did the 1/8 mile in just under 8 secomds, but I have the mickey thompsons street radial and they stick like glue, but very spendy..
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-10-2013, 07:41 PM   #3
1st stang's Avatar
My 1/8 was 8.42
Old 06-11-2013, 09:14 AM   #4
Napoleon85's Avatar
What tires are you running now?
Old 06-11-2013, 10:03 AM   #5
1st stang's Avatar
Goodyear eagle f1 255/40r19
Old 06-11-2013, 10:19 AM   #6
DustyStang306's Avatar
I would just get a set of sticky tires if you drag alot you will love them and are you still tuning stock gears in the rear?
DustyStang306 is offline   Reply With Quote
Old 06-11-2013, 10:29 AM   #7
1st stang's Avatar
Yea I still have the 3.15 gears and I haven't found a good tire for a 19x9 rim, do you know of any? In 10 weeks I was going to get cai and sct and alum. ds.
Old 06-11-2013, 10:35 AM   #8
1st stang's Avatar
Yea I still have 3.15 gears. I don't know any good tires for a 19x9 rim, do you have any ideas. In 10 weeks I was going to get cai, sct, and alum. ds.
Old 06-11-2013, 10:35 AM   #9
What I did was just get some crap used 2000 Mustang 16" wheels and slap some 28X10X16 drag slicks on there. 12.0 at 114 so far; shooting for an 11.
A low 12 on any of the factory tires is pretty close to impossible, based upon what I have seen. Most guys at the track on stock rubber are working at getting a deep 13.
Old 06-11-2013, 10:58 AM   #10
1st stang's Avatar
I was trying to find a drag radial for my 19" but can't find anything. Cause if I preload I have to have a full tank to get any traction.
Old 06-11-2013, 11:04 AM   #11
GypsyChris's Avatar
http://www.mickeythompsontires.com/s...StreetRadialII
They have them for a 19x9 rim I Assume you have the brembo wheels the tire size is 305/35/19 they work great.
GypsyChris is offline   Reply With Quote
Old 06-11-2013, 11:06 AM   #12
Ravnus's Avatar
i ran a 12.7 @111 on a Brembo rim...BF Goodrich G Force Comp 2...275/40/19 at 25psi
Ravnus is offline   Reply With Quote
Old 06-11-2013, 11:09 AM   #13
Um, I don't think you can cram a 305 on to a 9" BBP wheel with that little sidewall. That over 12" of tread width and section width is going to be a touch wider than that.
I'm pushing it cramming my 10" bias slick on a 7.5" Mustang wheel and that's on a 28" tall tire. There's a lot of overhang and I have to air down to minimum 18 pounds to get the tire to sit flat. A radial won't flatten as you air down.
Old 06-11-2013, 11:16 AM   #14
1st stang's Avatar
I've thought about trying mickey Thompson street comp out..
Old 06-11-2013, 11:19 AM   #15
GypsyChris's Avatar
I did it to my wheels lowered my psi to 15 stalled at 5k rpm and dumped the clutch lol or you can roll it out... But anyways the car hooked up and went
Old 06-11-2013, 11:25 AM   #16
1st stang's Avatar
See I was worried that a 28" tall tire would lower my gear ratio close to 3.00..
Old 06-11-2013, 11:38 AM   #17
Napoleon85's Avatar
You aren't going to get much more traction (from the tire) than you have now without buying wider wheels and tires.
The fact of it is that 19-20" wheels are great on the street and look really nice, but they SUCK for drag racing. There are very few tire options, and the ones available are outrageously expensive. They are also heavy, and the rotational mass will seriously slow you down.
I would give up on the whole "street tire drag racing" thing and get some 15-18" wheels and drag radials. Just keep them in the garage for trips to the strip and drive them down there.
Old 06-11-2013, 11:42 AM   #18
Ravnus's Avatar
Technically....on a 9 inch rim you shouldn't go wider than a 275. If someone has these MT's 305/35/19 on a Brembo wheel chime up.
Old 06-11-2013, 11:55 AM   #19
GypsyChris's Avatar
Me personally because I have a manual I'm gonna get some 17 inch e.t. Street mickey Thompson slicks and let it rip
Old 06-11-2013, 12:19 PM   #20
1st stang's Avatar
I think that's what I'm going to have to do so I can drive on them on the street when I need them. Cause right now I can't preload and that's the best part of having a auto
Old 06-11-2013, 12:38 PM   #21
I used to run a 315/45 16 et street on a v6 16x7 wheel. 1.6 60' and no issues with too much tire. 40 mile trip.each way on them.
Old 06-11-2013, 12:41 PM   #22
OzzyLiriano's Avatar
I was running 8.4 stock with 18" base model rims at the 1/8, I also have 3.15 gears, 2013 5.0
I recently went to the track with 20" rims with 275/35/20 up front and 295/35/20, nitto invos, bama race tune, x pipe, bmr lcas, and I ran 8.5 alllllll night!
So I bought some drag radials and 15" rims and the brackets to be ale to run 15 inch rims, hopefully I run mid 7s because if not I'm changing gears.
But! If I do run those numbers I'm doing a paxton or roush kit, I don't want run higher gears unless I'm staying n/a
OzzyLiriano is offline   Reply With Quote
Old 06-11-2013, 12:46 PM   #23
doug5.0's Avatar
I've got an 11 auto and the best I ran with the stock tires was a 12.78. I've since upgraded the tires to Bridgestone S04s and added 3.73 gears... But haven't re-run to see improvement. I agree it'll be hard to get low 12s without slicks or at least DRs. I just bought a cheap pair of 17" Mustang wheels on Craigslist and will slap DRs or slicks on em and use them only at the races. I'd rather use those than chew through my street tires.
CURRENT: 2016 GTPP, Vortech, Ford/Borla cat back, 1" drop on Vogtland, 1" Hubcentric spacers, APR Front Splitter, RTR Upper Grille.
SOLD: 2011 5.0, Auto, C&L CAI, Dyno Tuned, 3.73s, Boss 302 Intake, Magnaflow Competition axlebacks, Stallion Suspension LCAs, Whiteline Sway Bars.
doug5.0 is offline   Reply With Quote
Old 06-11-2013, 12:51 PM   #24
Keep us posted there is a huge debate about going 3.55 vs 3.73 on these auto but i have yet to find a auto 3.55 to compare
Old 06-11-2013, 01:17 PM   #25
1st stang's Avatar
Im planning on buying cai, sct, long tubes, 90mm tb, alum. ds and some drag radials and see if that wont put me close to a 12 flat
Old 06-11-2013, 01:22 PM   #26
1st stang's Avatar
How much did those 3.73 affect your mpg?
Old 06-11-2013, 02:10 PM   #27
tc x 4's Avatar
That will put you in the 11sec club.
Old 06-11-2013, 02:42 PM   #28
1st stang's Avatar
That's what I'm hoping for I'm really trying to keep it N/A
Old 06-11-2013, 06:35 PM   #29
I'm hanging right on 12 flat with just slicks, a Roush upper and cheap LCAs, on the procal tune. full option load car. You should be 11s with that plan w/o issue.
Old 06-11-2013, 08:27 PM   #30
DWC_SmOziLLa's Avatar
Buy ME Gear!!!
:cool
Official MustangEvolution.com Gear
Old 06-11-2013, 10:34 PM   #31
doug5.0's Avatar
19-20 in the city, I was driving through the Mojave last month and captured these pictures over the course of about 30-45 minutes. Really flat, really straight on cruise control. I've never been able to duplicate that though!
ID:	113686   Click image for larger version
Old 06-12-2013, 07:12 AM   #32
The Blue Dragon
GrabberBlue5.0's Avatar
Moved to at the track
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-12-2013, 08:21 AM   #33
1st stang's Avatar
Other then UCA and LCA is there any other suspension parts I need?
Old 06-12-2013, 08:57 AM   #34
The Blue Dragon
How deep are you wanting to get into drag racing?
Old 06-12-2013, 09:15 AM   #35
1st stang's Avatar
I drive the car most of the week cause my truck is bad on gas. But I'm at the track pretty much every other weekend
12:20 PM
