Time slips. - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 07-12-2013, 05:02 PM   #1
Oh2freshstang's Avatar
So I went to the track yesterday & I'm having some trouble understanding what happen with my time slips. What I don't understand is why my e/t's are lower but my mph are higher? This is compared to the last time I went. The difference in mods from last time & this was bbk LT headers w/catted xpipe! Also if u look at one of the time slips I had a 2.5sec lower et but my mph was higher & that was against a 3.7 with 3.55 gears. Thanks for any info!
ID:	117973   Click image for larger version
Old 07-12-2013, 05:04 PM   #2
Here's a couple from the 1st time I went.
ID:	117975   Click image for larger version
Old 07-12-2013, 09:59 PM   #3
White03GT's Avatar
My guess is your 60'. It was better the first times
White03GT is offline   Reply With Quote
Old 07-12-2013, 11:26 PM   #4
Yea but what I mainly don't understand is why everything is worse but my MPH are higher!
Old 07-13-2013, 01:40 PM   #5
White03GT's Avatar
It's because your 60'. Your mph is higher because your car has more power now. If you were to get a 60' like you did the first times your et would be quicker and your trap speed will be higher. It's all in your 60' man
Old 07-13-2013, 03:19 PM   #6
Your 60-330foot is the difference. On your best run your 330 was almost .4 better than your worst run. Your going to need to cut a sub 2 second 60 if you want really good times.
Old 07-13-2013, 09:02 PM   #7
Ok yea that makes sense! So to cut that 60 foot down I need to get those rear tires to grip better correct??
Old 07-13-2013, 09:25 PM   #8
White03GT's Avatar
Correct. Suspension too. Power isn't everything
Old 07-13-2013, 09:40 PM   #9
Yea I know some fatty rear tires & suspension is next on my list! I just didn't think the LT headers would make me spin so much!
Old 07-13-2013, 09:53 PM   #10
White03GT's Avatar
Do you do a long smokey burnout? And if so, do you have street tires?
Old 07-13-2013, 10:00 PM   #11
I am on street tires. & one run did a good burn out & another run I just spun them quickly & I got pretty much the same results. Do u recommend heating up street tires?? Also I switched rims & tires from my stock 215 to some 235 & that dropped my et.
Old 07-13-2013, 10:43 PM   #12
White03GT's Avatar
I would recommend avoiding the water box if you can and giving them a quick spin. Dont burn em out but just clean em off. Street tires get slick when hot.
Old 07-13-2013, 11:13 PM   #13
Ok cool ill try that next time thanks!!
Old 07-13-2013, 11:17 PM   #14
White03GT's Avatar
Anytime man. Good luck!
Old 07-13-2013, 11:19 PM   #15
Thanks man!
06:00 PM
