Questionn - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 09-24-2013, 07:46 AM   #1
Yzfoxracer's Avatar
Questionn
Would a 3.8l 2001 mustang beat a mid to late 90s v6 Oldsmobile lss (I think that's what it's called)
Yzfoxracer is offline   Reply With Quote
Old 09-24-2013, 07:51 AM   #2
JimmyMosqueda's Avatar
I don't see why not. As long as its on the track!
JimmyMosqueda is offline   Reply With Quote
Old 09-24-2013, 09:00 AM   #3
Yzfoxracer's Avatar
Of course on the track
Old 09-24-2013, 09:47 AM   #4
1slosix's Avatar
is this a legit question lol....yes you'll win even if you spin. luckily track prep does wonders.
carving corners like a boss
Old 09-24-2013, 05:54 PM   #5
Yzfoxracer's Avatar
Well theres a kid in my auto class and were going to a 1/4 track in October and he wants to race he thinks his is so much faster cause it's not a ford (typical GM guy)
Old 09-25-2013, 08:32 PM   #6
Yzfoxracer's Avatar
anything I should do to prepare and should I leave it in drive or shift from 1.2. Drive ?
Old 09-25-2013, 08:36 PM   #7
1slosix's Avatar
If you have traction control turn it off...turn off overdrive...put it in drive...don't floor it when the tree turns green...wait till the second amber light flashes then start leaning into the gas...your car won't start to roll till the light hits green which gives you a great reaction time with a bit of practice. Once you lean into it floor it...if you floor it off the bat you'll spin even in a sixxer or bog down and that's no good. Don't 1 2 shift...let the computer do the work it will out shift you I promise. Then repeat...I'd say race in the warm ups by getting there early so you can practice till its time to run him...
And above all else have fun! Win or lose you will have a blast.
Old 09-25-2013, 08:38 PM   #8
1slosix's Avatar
BTW...after some practice you may try preloading the torque convert by holding the brake and the gas a bit to about 1500 rpms...that'll help give you a jump when you start. Of course you have to learn to let off the brake as you press in the gas at the same time. If you have an empty lot to practice in give it a shot.
Old 09-25-2013, 10:33 PM   #9
What type of car does he have?
Old 09-26-2013, 04:50 AM   #10
Yzfoxracer's Avatar
it's a mid to late 90s Oldsmobile with a 3.8l front wheel drive it's a 4door too
---------- Post added at 06:50 AM ---------- Previous post was at 06:48 AM ----------
alright thanks for all that info this will be my first time at the track and I'm hoping It will be fun
Old 09-26-2013, 09:51 AM   #11
Ish416's Avatar
If you are running a stock, auto 3.8 Mustang, my money would be on the Olds. Assuming its a 95+ (3.8 Series 2) and is in decent shape.
Also, some of those Olds came with the super-charged 3.8.
Old 09-26-2013, 04:10 PM   #12
Yzfoxracer's Avatar
Originally Posted by Ish416 View Post
If you are running a stock, auto 3.8 Mustang, my money would be on the Olds. Assuming its a 95+ (3.8 Series 2) and is in decent shape. Also, some of those Olds came with the super-charged 3.8.
it's a 94 3.8 without the super charger
02:07 PM
