For road racing or autocross: do suspension mods make much of a difference? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 02-06-2014, 03:10 PM   #1
Bryanw92's Avatar
I know they make a difference, but is the difference significant enough to be worth the money?
Does anyone have any lap times to post before and after a suspension upgrade?
I'm looking at something like the Ford Racing kit with shocks, springs, sway bars.
Bryanw92 is offline   Reply With Quote
Old 02-06-2014, 05:05 PM   #2
Yes! Suspension mods make a tremendous difference.
The tires are where the big gains are made though...
Old 02-06-2014, 06:16 PM   #3
Mile high JDF's Avatar
+1^ I don't have lap times unfortunately, but a spring upgrade on my car helped reduce nose dive and made it a but tighter in the turns. Then I swapped to an IRS and set my alignment specs to give me a bit more toe out and that helped greatly with turn in and steering response in a turn. I haven't made a trip out since my latest batch of upgrades though
Sent from my XT1030 using Mustang Evolution mobile app
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-06-2014, 07:03 PM   #4
Bryanw92's Avatar
This is also my daily driver, so putting track tires on the car is not practical. But, "tremendous difference" is what I was hoping for!!
Old 02-06-2014, 07:11 PM   #5
Summer tires make a pretty big difference compared to running the stock all seasons. I have to push it pretty hard to make money break loose
Old 02-06-2014, 08:26 PM   #6
tj@steeda's Avatar
You can see the before and after in this video:
MM&FF at the Test Track with a 5.0 « Steeda Blog
Let me know if I can get into a similar package?
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
Win A $300 Gift Card
tj@steeda is offline   Reply With Quote
Old 02-07-2014, 11:58 AM   #7
Bryanw92's Avatar
Best Regards,
TJ
That's the kind of package I'm looking for. (And I wish I could get on to the Gainesville Raceway road course. LOL)
Old 02-07-2014, 02:50 PM   #8
tj@steeda's Avatar
Send me an email at tim@steeda.com if you would like to discuss packages.
Also, your kind of close to Valdosta, so if you are interested ... Mark Your Calendar – 2014 Pony Wars! « Steeda Blog
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 02-14-2014, 06:12 PM   #9
Region: Nevada
As stated, the tires are going to make the biggest difference. Simply swapping from the all weather to summer series will be a huge change. The biggest handling issue that I had with the stock mustang GT suspension was with body roll, dive, and the horrible tendency to understeer.
This can largely be fixed with a good set of shocks. I swapped Koni Yellows into mine, took it out to an improvised skid pad and dialed it in on the new tires. Makes a WORLD of difference.
I was envisioning having to change the front or rear sway bar but I am holding off for now.
The overall characteristics are very well balanced now and I am leaving it alone.
For the record, these changes can be made while remaining in F-Stock SCCA class.
-Static
Static_LV is offline   Reply With Quote
Old 02-14-2014, 06:19 PM   #10
Bryanw92's Avatar
-Static
I'm trying to keep the car daily-driverable, so I'm avoiding summer tires. But, the body roll, dive, and understeer is really annoying since my last car was a Genesis Coupe so I got spoiled by the incredible handling.
So you changed the shocks but kept the stock springs?
Old 02-14-2014, 06:31 PM   #11
What year and model is your car? That will help figure out what is best for your car.
Old 02-14-2014, 06:31 PM   #12
Region: Nevada
That is correct.
The stock spring rates are actually not bad. The problem is that the stock shocks are way too soft. Great for road trips and that Cadillac feel, not so great for autocross or road racing type applications. The Koni Yellows on the softest setting are much more positive and help a TON.
I run them like that for daily driving and they are just fine. At the track I have settings that are a lot harder. It is possible to go too hard though and the spring will not be able to return to its neutral position fast enough if you tighten these down too much. The trick is finding that line or going to different rate springs.
-Static
Old 02-14-2014, 06:37 PM   #13
Bryanw92's Avatar
It's a 2014 GT.
Old 02-14-2014, 06:56 PM   #14
Maximum Motorsports answers emails and the phone. Contact them with any questions.
LINK:
Suspension
If on a "budget", although all suspension set-ups are very expensive.
For me- I want a superb handling car for safety and spirited driving. Basically, I just lowered the cars I have. I believe that I have done it the right way. I have a SN95, a '97 coupe & a '96 Cobra.
I just lowered them both, thats all. Parts list:
springs, shocks/struts, caster camber plates, X2 balljoints, bumpsteer kit.
Thats the most simple suspension upgrade to do but the results are unbelievable.
Good Luck! Enjoy.
Old 02-14-2014, 07:41 PM   #15
I don't know where you live, but in most places, summer tires DO NOT deter from the driveability of the car at all, in fact, they enhance it.
Sure they may be a little noisy and wear out faster than you're used to, BUT, the tires are everything.
Shocks are important as well, although, I've seen some smokin' fast Coyote powered cars in F-stock, that were all stock except for 200 treadwear summer tires! Those cars, well driven, are routinely faster than the modified New Edges that dominate ESP. Hell, I've seen Coyotes in F-stock that were faster than Coyotes in ESP!!!
You'll get used to the Mustang handling... you just have to keep the front end down .
Old 02-14-2014, 07:47 PM   #16
Bryanw92's Avatar
I've had summer tires before. I'd rather spend my money on durable mods first.
Old 02-15-2014, 01:41 AM   #17
I drove my summer tires in god awful rain and they did amazing.
Old 02-15-2014, 01:44 AM   #18
It's a 2014 GT.
1. Springs/shocks/struts
2. Watts Link
3. Torque Arm
4. Rear Lower control arms
5. Brakes upgrade
Your car will feel completely different with those items.
Old 02-17-2014, 12:09 AM   #19
ROUSH engineered A/S tires I have are the best all around tires I've had yet. Good for the track, rain, snow-
Cooper RS Zeon-Cooper Tire & Rubber Company - Cooper Zeon RS3-A™
Old 02-17-2014, 04:51 PM   #20
LINK:
Suspension
Good Luck! Enjoy.
+1 this is a great choice
Arustik is offline   Reply With Quote
What mods can get 350+hp? Johnstonb93 2005-2010 V6 Mustang 101 11-06-2017 12:25 PM
NMRA "Super 'Stang" rules and regulations rebeltx At the Track 4 03-06-2013 12:02 PM
Front end appearaance, or suspension mods? Can't decide OrganDonor 2011-2014 Mustang GT 14 12-28-2012 09:08 AM
Do roller rockers make a difference? foxbox 1979-1995 Mustang GT 10 10-01-2012 04:43 PM
what kind of difference do light weight wheels make my90gtamfw 1979-1995 Mustang GT 2 10-18-2011 09:07 PM
11:43 AM
