Launch - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 03-04-2014, 11:43 PM   #1
sunnytan06's Avatar
Launch
Any tips of how to launch a 3.7?
sunnytan06 is offline   Reply With Quote
Old 03-05-2014, 01:20 PM   #2
Mustangs's Avatar
What's your gear ratio?
Mustangs is offline   Reply With Quote
Old 03-05-2014, 01:22 PM   #3
Mustangs's Avatar
Auto or manual?
Old 03-05-2014, 02:47 PM   #4
Oh2freshstang's Avatar
^+1
Old 03-05-2014, 07:04 PM   #5
Foot on the floor!
royalpurple is offline   Reply With Quote
Old 03-06-2014, 05:37 AM   #6
sunnytan06's Avatar
Sorry for the lack of information.
It is a 2,73 manual
Old 03-06-2014, 09:27 PM   #7
Ish416's Avatar
I seem to get the best launches around 2300 +/- a few hundred rpm, depending on traction. Sometimes slipping the clutch can help too with the tall gearing.
Also, traction and stability control should be off.
Old 03-06-2014, 11:26 PM   #8
Originally Posted by Ish416 View Post
I seem to get the best launches around 2300 +/- a few hundred rpm, depending on traction. Sometimes slipping the clutch can help too with the tall gearing. Also, traction and stability control should be off.
+1 best way is to get out to the track & practice! Try different launching RPMs & see what works best for u. Track prep plays a big part too!
Old 03-07-2014, 12:17 AM   #9
2011 Kona Blue's Avatar
Originally Posted by royalpurple View Post
Foot on the floor!
Bro Amen! That's how I roll. I get the same exact launch every time. Pull up to the light. Left foot on the brake. Right foot over gas pedal. Light turns green, slam right foot down on the gas pedal too the floor. At same time lift off brake pedal.
Traction control off. Car is in drive and bammmmm son. Blast off. It works exactly the same time every time. Just nail the gas pedal too the floor. The computer in the auto does the rest. Easy peasey!
Its the most consistent way to launch every single time.
Old 03-07-2014, 07:39 AM   #10
GrabberMeBlue's Avatar
Launch
If you're waiting until the light turns green to nail it, you're waiting too long. Also, the OP has a stick, not auto. Search for a thread called Bracket Racing. It was fairly recent and a couple of us talked about staging, etc. I haven't had a chance to get the Mustang down there yet, but with other autos I have raced in the past I get the RPMs up (same point every time) while holding my foot on the brake and then let my foot off and nail the gas at the same time when it is time to go. I get less wheel spin this way as you are loading the driveline and not having such an abrupt change as you would nailing it from idling RPMs.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 03-07-2014, 08:19 AM   #11
Originally Posted by GrabberMeBlue View Post
If you're waiting until the light turns green to nail it, you're waiting waiting too long. Also, the OP has a stick, not auto. Search for a thread called Bracket Racing. It was fairly recent and a couple of us talked about staging, etc. I haven't had a chance to get the Mustang down there yet, but with other autos I have raced in the past I get the RPMs up (same point every time) while holding my foot on the brake and then let my foot off and nail the gas at the same time when it is time to go. I get less wheel spin this way as you are loading the driveline and not having such as abrupt change as you would nailing it from idling RPMs.
Lol. My bad! Guess I should pay more attention to OP's post about having a manual. Lol
Old 03-07-2014, 10:24 AM   #12
sunnytan06's Avatar
How to turn off the stability control on manual?
Old 03-07-2014, 10:32 AM   #13
Ish416's Avatar
Hold down the brake pedal and hold the traction control button down for like 6 seconds. It will say "advancetrac off" or something like that.
Old 03-07-2014, 10:50 AM   #14
sunnytan06's Avatar
Thanks. No wonder my launch always feel restricted. I only turned off the traction control
Old 03-07-2014, 11:17 AM   #15
Ish416's Avatar
Make sure you are ready for the rear end to step out a bit, because it will.
Automatic launch GTstang07 2005-2010 Mustang GT 56 12-07-2014 07:13 AM
How high Rpm should I launch runvsofthisbull 1996-2004 Mustang GT 8 01-22-2014 08:45 AM
launch control question RiceKillerGT 2011-2014 Mustang GT 12 08-26-2013 05:53 PM
07:39 PM
