Any other Procharged Coyotes in here? - Mustang Evolution
Go Back   Mustang Evolution > Ford Mustang | Wrenching, Care and General Topics > At the Track
Old 06-08-2014, 04:55 PM   #1
RJ13GT's Avatar
How does yours run in the 1/4 mile? Mine seems kind of slow. I have not ran it since my pulley swap and retune but It doesn't feel like it's going to do much better. I'm going to find out next Friday weather permitting.
I have the standard P1SC stage 2 kit bolted onto a otherwise stock A6 with 26'' drag radials. It ran 11.98-12.0@120, 2.0 60's @6.6 psi. Good air and good traction. I was hoping for it to be a little quicker than that out of the box with a tune. The first tune made 521 rwhp, 430rwtq (STD).
I had it retuned with a different tuner on a different dyno with a 4.25 pulley that brought the boost up to 7.8psi and power to 506rwhp, 416rwtq (SAE). The numbers are not too promising but he said his dyno reads low. Similar fueling and timing as the first tune. So I'm going to see if there is any improvement at all with the retune. If it's not balls deep into the 11s it looks like I have some more wrenching to do.
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 06-08-2014, 05:06 PM   #2
610swolf's Avatar
any suspension mods?
610swolf is offline   Reply With Quote
Old 06-08-2014, 05:37 PM   #3
RJ13GT's Avatar
Not at the time. I just installed some BMR rear lower control arms yesterday. I wasn't getting any wheel hop or anything at the track. The new control arms are a major improvement i can tell. The car goes straight when i do a burnout instead of going sideways and kicking out to the side.
Sent from my SCH-S720C using Tapatalk 2
Old 06-08-2014, 08:45 PM   #4
Do uppers,lowers and adjustable pan hard. All Bmr
---------- Post added at 02:45 AM ---------- Previous post was at 02:44 AM ----------
Struts and shocks be a huge help also!
royalpurple is offline   Reply With Quote
Old 06-12-2014, 09:47 PM   #5
BaSohol's Avatar
My buddy runs 11.5s in his AED e85 tune only 2013 CS/GT only this is removed sway bar and Hoosier qtps
Also with that power you probably need a 28" tall tire
2007 Ford Mustang GT 5spd
Old 06-12-2014, 10:30 PM   #6
I would do some suspension work and learn how to launch with the drag radials. I know guys with stock 5.0s in the 11s with radials and a few suspension mods cutting 1.5-1.6 60 ft times. 2.0 is good for street tires but not drag radials. power isn't your issue, it's getting off the line and putting that much power to the ground that is causing the times not to be what your expecting.
StarzTA17 is offline   Reply With Quote
Old 06-13-2014, 04:51 AM   #7
RJ13GT's Avatar
Yea i have drag radials dead hooking. 2.0 is as good as it gets. Im going to buy a circle d converter here shortly. The 60' is killing it.
Old 06-13-2014, 07:46 AM   #8
BaSohol's Avatar
My buddy cuts 1.6s in his 6spd car, stock suspension
I cut 1.7 in my 3v 5spd car, just have LCAs and lowering springs
It's about the tire, drag radials kinda suck,
Hoosiers QTPs
Old 06-14-2014, 01:59 PM   #9
RJ13GT's Avatar
No its not my tire. My car is an auto. I couldn't spin them out of the hole at the track if you paid me to. Its a super tight converter. 2.0 60 is all it has after about a dozen runs and Im not a newbie. A circle d 3c is coming in the near future.
e85 and proper oil in coyotes. Rapinator126 2011-2014 Mustang GT 52 01-05-2014 07:43 PM
For all supercharged coyotes Mustang_5.0 2011-2014 Mustang GT 4 06-03-2013 10:11 AM
Procharged V6 selling on classified's here sprdave 2011-2014 V6 Mustang 2 01-21-2013 11:24 AM
03 cobra vs procharged ls1 video Zim The Bar 15 08-02-2005 01:18 PM
02:03 AM
